Oil Connection
Old Jul 26, 2004 | 11:04 AM
Dreizehn's Avatar
Oil Connection
Has anyone used one of these?
Distribution Block
If not, what have you guys that doesn't leak?
Old Jul 26, 2004 | 12:15 PM
Dreizehn's Avatar
Distribution Block
I found a cheaper solution:
http://www.pegasusautoracing.com/
Part No. 1073
Hope this helps if anyone needs it.
Old Jul 26, 2004 | 12:29 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
good luck connecting all those accessories and a feed line all to that one tee...with all the vibrations from the block combined with the weight of the OEM sender, aftermarket sender and feed line, you'll be lucky if that T doesn't crack off in the block...seen it plenty of times on Hondas(and on an integra last week while was driving...no fun)
IMO...mount it on the firewall, run a 3an line from the block to the T mounted on the firewall and mount all the OEM and aftermarket sensors and feedlines there.
Old Jul 26, 2004 | 12:36 PM
Dreizehn's Avatar
Good call. I'm just now getting to that point. I ordered the connections from Pegasus, I'll be able to do what you suggested that way.
Old Jul 26, 2004 | 12:42 PM
DA-MAX's Avatar
some godd info
http://www.honda-tech.com/zerothread?id=377208
http://www.honda-tech.com/zerothread?id=862213
you guys could also look into this-->
http://www.alamomotorsports.com/prod...ckadapter.html
had one on my integra.
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
zmcneely13
Sep 26, 2015 02:26 PM
