50 shot and ecu Qs
Old Jul 27, 2004 | 10:22 AM
JeEvE's Avatar
50 shot and ecu Qs
Im thinking about getting a 50 shot, not sure either dry or wet yet. Im planning to get a TS ecu before but I read a post before that it wouldnt be safe to run nitrous with the ecu because the advanced timing and other things. Also, where can I put the nozzle with my hacked airbox?
Old Jul 27, 2004 | 02:42 PM
michaelnyden's Avatar
you would need the J&S ultrasafeguard to run nitrous with the TS ecu....cause the ultrasafeguard comes with a wire that you wire into your nitrous selenoid so that when you activate the selenoid via a toggle switch or other method, the J&S turns down you timing to what you specify....stock would be a good number...the J&S safeguard basically taps into your ecu and tells it to turn down the timing from there...
Old Jul 27, 2004 | 02:55 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Have you called TS and talked to them about an ECU for Nitrous?
Old Jul 27, 2004 | 03:32 PM
SonicDust187's Avatar
Bags in our little nitrous section. WOW, welcome. Please stay.
Old Jul 27, 2004 | 03:50 PM
wow bags is in the nitrous section...didn't even notice...LOL...I talked to Danny at TS and they said cause of the inherent design difference in their ecu's vs. Jwt's, they can't do a seperate nitrous program
Old Jul 27, 2004 | 04:46 PM
Bags's Avatar
Ahh.. Ok , thanks
And sonicdust187, I am staying.. Just trying to learn some info before I post.. I will open my mouth and insert my foot, but I am trying to limit that..lol
Old Aug 5, 2004 | 11:25 PM
JeEvE's Avatar
Is anyone running the J&S ultrasafeguard?
Old Aug 6, 2004 | 01:22 AM
Jime is...
Old Aug 6, 2004 | 03:43 AM
Jime's Avatar
Not me, I run stock ecu and S-AFCII. I am not a TS ECU believer.
Old Aug 6, 2004 | 12:16 PM
no i was saying you are running a J&S
Old Aug 6, 2004 | 12:22 PM
Jime's Avatar
Not running a J&S just the S-AFCII.
Old Aug 18, 2004 | 10:14 AM
95maxrider's Avatar
Lightly modded
You could get the JWT nitrous daughterboard to go along with their regular ECU. It retards timing and alters the A/F ratio.
Old Aug 18, 2004 | 04:18 PM
bruteMax's Avatar
I'll be installing the Safeguard unit as soon as it gets here. John is taking his time apparently...
I wouldn't get a jwt nitrous ecu - gawd that's a waste of money. An ecu that binds you to a fixed timing retard whenever you switch to nitrous mode. If you want the n/a benefits of an ecu with advanced timing just get the cheaper of a ts or jwt, and invest in a J&S Safeguard.
Of course the best option of all is to not get your ecu modified if you're going fi. I wish I never did get my TS ecu.
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
mix master
Sep 4, 2015 05:50 PM
