help me analyze my plugs...
Old Jul 30, 2004 | 07:41 AM
Requin6's Avatar
i am no expert on reading plug wear so if i could have another couple sets of eyes to take a look i would appreciate it.
this is after ~10k miles - NGK BKR6E11 1 step colder.
thank you.
--Paul
Old Jul 30, 2004 | 07:47 AM
Stephen Max's Avatar
thank you.
--Paul
It's hard to tell anything without seeing a close up of the electrodes. But from what I can see they look pretty normal, no sign of oil fouling or excessive richness. Just make sure there aren't any silvery deposits on the electrode or insulator tip, which would indicate leanness.
Are you regapping or keeping the .043" gap?
Old Jul 30, 2004 | 07:52 AM
Requin6's Avatar
i keep the gap at .043. thanks for the feedback, there doesnt appear to be any deposits on the electrode or tip.
--Paul
Old Jul 30, 2004 | 04:45 PM
MardiGrasMax's Avatar
The only way to properly read plugs if to do a full throttle blast just like a 1/4 mile run, then imediatly shut the car off and pull the pugs. If you let it run after the full throttle blast they will clean themselves up. I recomend you get a new set, gap them to ~.033, install then do a blast and check them, thats how you do it.
FWIW, the electrode should be discolored from getting hot, like a weld. the discoloration should travel down the electrode a ways, no more than 2/3 the way down. If the discoloration touches the threads youve got too much heat, lean or DET.
Paul, call me with questions.
Old Jul 30, 2004 | 10:25 PM
matty's Avatar
See the discolaration hes gettin on the bottom white part of the plug. I got that same brownish color on my front 3 plugs before boost...what does that usually mean ??
-matt
Old Jul 31, 2004 | 11:36 AM
-matt
Oil leaking past the valve cover seals into the spark plug recess (not the combustion chamber), maybe.
Old Jul 31, 2004 | 04:34 PM
matty's Avatar
No, its like a burn on the white part of the plug that doesnt really come off when you rub it...thats how I know its kinda like a burn
You can tell kinda in the pic on a few of them
-matt
Old Aug 2, 2004 | 08:23 AM
Its normal for plugs that have been in for a while.
-matt
Old Aug 2, 2004 | 01:52 PM
spirilis's Avatar
All spark plugs I've serviced with a decent amount of life on them had that too... including the ones I pulled this weekend (I'm stock N/A, no oil control problems)
speedemn
1/4 and 1/8 Mile Racing
Apr 25, 2004 07:41 PM
VQdriver
36
Nov 27, 2002 10:05 AM
bill99gxe
Jul 2, 2002 02:36 PM
bill99gxe
May 15, 2001 07:31 AM
bill99gxe
Jan 10, 2001 11:09 AM
