Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Pressure Wash Engine Bay???
Old Jul 30, 2004 | 10:16 PM
str8max's Avatar
Any1 ever done this?
Cause any problems??
Did it do a good job?
Old Jul 31, 2004 | 10:06 PM
BensMax93's Avatar
Im not sure what you mean by "pressure wash," but I cleaned my engine bay using a garden hose on full 'pressure.' Its pretty easy, but make sure you cover up the vitals of the engine like a cone filter (if you have one), the battery terminals, sparkplugs, alternator, etc...You should check out the stickies-they have lots of detailing info. I bought engine degeaser from wal-mart for a $1. You just spray all over the engine, let it sit for 10-15 minds and hose it off. Check out the results:
Before
After
Ben
Old Aug 1, 2004 | 02:40 AM
Ant96GLE's Avatar
VG powa!! Garden hose yes... Pressure wash NO!!!!
You dont want water at that kind of pressure on your engine where it can get into any kind of electrical terminal. sad but true I used to work at an auto parts store and there was a gas station with a pressure washer next door. Some guy in a 4th Gen brought his car there and had the engine bay pressure washed... it turned on for about a minute and turned off... it wouldnt turn on again. he eventually had it towed...
Old Aug 1, 2004 | 04:53 AM
SilverBelle04's Avatar
You'd be fine if you do what BensMax93 suggests.
Bob
Old Aug 1, 2004 | 04:33 PM
Bman's Avatar
I'm not much of an engine bay detailer, but I would never use a pressure washer to clean an engine bay.
Judicious use of degreaser, a soft brush, and a garden hose should do it.
Old Aug 3, 2004 | 11:55 AM
maximus_96's Avatar
does the degreaser work on the hoses too? or just on the engine block?
Old Aug 23, 2004 | 11:27 AM
Chad Valk's Avatar
Spray Simple Green, stay away from the vitals like it was stated earlier, garden hose with the pressure **** off and use the old thumb over the end trick to direct a little water pressure. Cleans up nicely.
Of course, I haven't done this in a while because I have a dealer nearby that washes, waxes (hand and machine), does the windows inside, armor alls, vacuums and shampoos interior + trunk, shines the wheels and chemical cleans the engine for a hundred bucks. Better use of my time and money to let them have at it once a year
Old Aug 23, 2004 | 02:54 PM
CandiMan's Avatar
Say Candyman 5 times
Can I get a piece of this? Here are my before and after pic. First I spray engine degreaser, and after letting it soak for a few minutes I scrub with a brillo pad. It's the engine bay we're talking about so I wasn't concern about the fine scratches the brillo pad might make. After my first scrubbing then I used Simple Green, let that soak for a few minutes then started the scrubbing again. Finally I used a garden hose and rinse.
BEFORE
AFTER
BEFORE
AFTER
Old Aug 23, 2004 | 11:50 PM
superblack98se's Avatar
You can pressure wash an engine, you just have to do what Ben said, cover up the "vitals"....
derekinthez
Nov 13, 2022 04:00 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
adamgalazka
Sep 9, 2015 03:39 PM
