Cam Sensor Retainer
Old Aug 2, 2004 | 12:11 AM
matty's Avatar
Cam Sensor Retainer
V1 kit going in..I do not have the Cam sensor retainer.
Stillen wants $37.50 for this part so I figured I would make one
anyone have a pic of what it looks like or any ideas to using something cheap in place of the retainer or maybe not even using it at all ??
thank you
matt
Old Aug 2, 2004 | 09:39 AM
Chunger's Avatar
My other car is a Hybrid
It's really only a flat piece cut to hold the sensor in place in a "rotated" position... The piece is hard as heck to remove else I'd scan it in for you. Maybe someone is changing a belt/pulley could do it for you. I assume the V1 and V2 piece are the same.
Old Aug 2, 2004 | 12:59 PM
KMax2988's Avatar
Hey Matt. Lemme see if I can mock something up for you. If I can find a spacer of the right size I can fashion a retainer using some flat stock. Too bad you didnt post this b4 I changed my cam sensor or I'da gotten you a pic as well.
~Keith
Old Aug 2, 2004 | 02:33 PM
wildr0id's Avatar
thank you
matt
I took a big enough washer and bent it in half to form about an 90 dergree angle for the washer and bolt it to the hole and the sensor has not moved since
Old Aug 2, 2004 | 02:56 PM
Chunger's Avatar
Maybe this will help... hard to see but it's the best I have:
Old Aug 2, 2004 | 03:09 PM
matty's Avatar
So its anything that holds it in, 45 degrees left of where it sits stock ?? i may be able to find something to use...
a pic would be good
-matt
Old Aug 2, 2004 | 05:50 PM
MardiGrasMax's Avatar
I didnt use it
Old Aug 2, 2004 | 06:14 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
matty, i didnt have mine with the kit - just like i mentioned - u dont really need it. It's not like it'll fall out either, it's a snug fit; just loosen the sensor, clock it the way u need it
Old Aug 3, 2004 | 07:03 AM
Stephen Max's Avatar
Me three. My kit didn't come with one, so I didn't use it.
Old Aug 3, 2004 | 07:19 AM
matty's Avatar
put the bolt back in, or dont even bother
Old Aug 3, 2004 | 08:14 AM
i went just like stock
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
