How to adjust idle??
AFAIK there is no screw to tighten, idle speed is controlled by the idle air control valve/idle air bypass, which is an electric device/motor that allows air to enter the engine when the throttle is at 0%. Federal emissions won't allow hand-adjusted (screw-type)idle or mixture settings on anything made since 1978.
Try the Idle Air Volume reset procedure (you'll have to search for it, I don't have a link) since you've already done an ECU reset. My 2k2 idles at 750-775 in drive (auto.) 600 does not seem excessively low for your MT, and 600 should be enough for your engine to run ok and the alt. to charge unless you have UDPs.
tarun900
19
Dec 20, 2021 06:57 PM
