where to buy reall SS briaded line?
uhm im not sure out there but here in cali we go to earls plumbing and get SS lines. you can try Jegs they sell alot of SS line stuff there also pretty cheap. Is this for your feed line. If so it is 16 feet I believe, I dont remember myself and im on my second line. Damn dropped cars
ive had this kit on for 3 months and ive ruptured 2 lines... Jegs sells sh|tty quality lines that arent truely SS line, ill check the plumbing stores... should i try a local plumbing store or a plumbing supply warehouse? and yes it is for my n2o feed from bottle,
Don't bother with the plumbing stores go to a hydraulic shop they will make any length you want with a much superior quality line. They deal with pressures much much higher than nitrous, plumbing stuff will not work.
Originally Posted by DaThrillr
i believe 4AN ... its for my N20 feed line from bottle..from what i remember it was 4an
either make it or have a shop make u a hose using Earl's Speed Flex. its teflon lined and it's used for high pressure apps..IE brake line, clutch.
if you're good in making hoses you can do it yourself..procedure for putting on the hose ends are different than the regular rubber braided. since theres a teflon liner it will hold up to the nitrous pressure better...and it probably won't seep as much compared to just rubber braided.
since you're in NY...look up moreland hose.
Moreland Hose & Belting Corp
Address: 135 Adams Ave, Hempstead, NY 11550
Phone: (516) 485-9898
see if they can make you something for your system.
ok sounds good ill look them up, any price i can use as reference to make sure they arent ripping me off... and will this braided line be stronger then the cheesy NOS brand feed line?
it's a hose...can't bungee off it ya know.
put it this way...this hose is used for brake lines and high pressure set ups...where as the regular braided/rubber hoses are not.
ivorton23
Sep 28, 2015 09:08 PM
