where to buy reall SS briaded line?
Old Aug 28, 2004 | 12:09 PM
DaThrillr's Avatar
title says it all....and i dont remember how long do i need it?
Old Aug 29, 2004 | 09:19 AM
desertmaxima's Avatar
uhm im not sure out there but here in cali we go to earls plumbing and get SS lines. you can try Jegs they sell alot of SS line stuff there also pretty cheap. Is this for your feed line. If so it is 16 feet I believe, I dont remember myself and im on my second line. Damn dropped cars
Old Aug 29, 2004 | 11:31 AM
DaThrillr's Avatar
ive had this kit on for 3 months and ive ruptured 2 lines... Jegs sells sh|tty quality lines that arent truely SS line, ill check the plumbing stores... should i try a local plumbing store or a plumbing supply warehouse? and yes it is for my n2o feed from bottle,
Old Aug 29, 2004 | 12:18 PM
Jime's Avatar
Don't bother with the plumbing stores go to a hydraulic shop they will make any length you want with a much superior quality line. They deal with pressures much much higher than nitrous, plumbing stuff will not work.
Old Aug 30, 2004 | 07:54 AM
DanNY's Avatar
Ad·min·is·tra·tor
what size do u need? 3AN? 4AN? 6AN? (not too up on N2O specs).
Old Aug 30, 2004 | 02:19 PM
DaThrillr's Avatar
i believe 4AN ... its for my N20 feed line from bottle..from what i remember it was 4an
Old Aug 31, 2004 | 06:08 AM
DanNY's Avatar
Ad·min·is·tra·tor
either make it or have a shop make u a hose using Earl's Speed Flex. its teflon lined and it's used for high pressure apps..IE brake line, clutch.
if you're good in making hoses you can do it yourself..procedure for putting on the hose ends are different than the regular rubber braided. since theres a teflon liner it will hold up to the nitrous pressure better...and it probably won't seep as much compared to just rubber braided.
since you're in NY...look up moreland hose.
Moreland Hose & Belting Corp
Address: 135 Adams Ave, Hempstead, NY 11550
Phone: (516) 485-9898
see if they can make you something for your system.
Old Aug 31, 2004 | 02:50 PM
DaThrillr's Avatar
ok sounds good ill look them up, any price i can use as reference to make sure they arent ripping me off... and will this braided line be stronger then the cheesy NOS brand feed line?
Old Sep 1, 2004 | 03:26 PM
DanNY's Avatar
Ad·min·is·tra·tor
hmm stronger? stronger how?
it's a hose...can't bungee off it ya know.
put it this way...this hose is used for brake lines and high pressure set ups...where as the regular braided/rubber hoses are not.
matts95max
Apr 23, 2025 10:44 AM
spazma7ik
Jan 12, 2017 09:38 PM
ivorton23
Sep 28, 2015 09:08 PM
Johnny9595
Sep 16, 2015 07:20 PM
