Gauges under radio
Old Aug 29, 2004 | 08:14 AM
quickie's Avatar
Gauges under radio
Hi, I've seen a couple of maximas with a three gauge pod under the radio. Does anyone have a how to or pictures for this. I dont want pics of gauges on the A pillar, just under the radio. Thanks
Old Aug 29, 2004 | 09:59 AM
Linkage23's Avatar
you can find the gauge bezel for the 3 pgauages on HKXUSA.com or something like that.....the down side of that is buying the gauages too. HKS is too expensive IMO. Hope this helps.
Old Aug 29, 2004 | 10:22 AM
Vyrus's Avatar
Correction: www.HKSUSA.com .. the problem is that the bezel is for metric sized gauges (63mm I believe), and most gauges sold in the U.S. are standard (2-1/16"). You can dremel them to fit U.S. standard size gauges, which is most practical since buying HKS gauges is $$$$$$$$.
-Cyrus
Old Aug 29, 2004 | 02:23 PM
quickie's Avatar
So is it just the Type B one for 65.97? Does it come with the gauges and the bezel? Thanks
Old Aug 29, 2004 | 02:34 PM
Vyrus's Avatar
Yes it is the Type B for $65.97. It does NOT come with any gauges, and the HKS gauges are about $150 each. That brings you to a total of $410?
If anybody is looking for the Type-A bezel, I have one I will sell for $15 shipped! Check 2nd page on Cardomain.
-Cyrus
Old Aug 29, 2004 | 02:41 PM
nostrixoxide's Avatar
Vyrus,
63mm is a larger opening the 2-1/16" So you would not need to dremel the openings to accomidate Autometer gauges. The Autometer gauges would fit in the hole, but they would be very loose.
1" standard ='s 25.4mm metric
2-1/6" standard ='s 50.8625mm metric
Sorry for the math lesson. I just didn't want to see anyone buy a product expecting smaller holes, when the holes are actually larger....
Old Aug 29, 2004 | 02:45 PM
Vyrus's Avatar
Originally Posted by nostrixoxide
Vyrus,
Nah it was my bad. I meant to say they were 46mm, which is smaller than 2-1/16". Don't know where I got 63mm from!
-Cyrus
Old Aug 29, 2004 | 07:53 PM
No problem, it was an honest mistake
Old Aug 29, 2004 | 08:07 PM
1MAX2NV's Avatar
HKS with autometer gauges. Took about 15mins worth of dremel sanding drum to make the holes large enough to fit.
Old Aug 30, 2004 | 12:30 PM
quickie's Avatar
It looks nice but why would you need to dremel the HKS to make the autometer gauges fit if the HKS holes are bigger than the gauges?
Old Aug 30, 2004 | 01:07 PM
Chunger's Avatar
My other car is a Hybrid
Obviously because they are not large enough for the 52mm Autometer gauges...
It has to be done... trust us...
Old Aug 30, 2004 | 01:59 PM
MAXRB8's Avatar
I chose to go to an A-pillar instead, all 3 Equus gauges 2 1/16" mechanical $38. The gauges came in an underdash triple holder.
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
