Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Best stuff for removing hard water spots
Old Aug 31, 2004 | 11:41 AM
maximadave's Avatar
detailerdaveb@gmail.com
I detail my Mom's '04 350ZR about once a month and where she parks at work there are some stubborn hard water spots. Has anybody used any stuff they can recommend?
Old Aug 31, 2004 | 02:58 PM
Bman's Avatar
For hard water spots (actual mineral deposits) try vinegar or vinegar solution first. I've never tried this myself though, so I'm not sure by how much you should dilute it....
Old Aug 31, 2004 | 04:13 PM
CanadianMoFo's Avatar
50/50 is safe. Thats the usual ratio for window cleaner. Try that first and if it doesn't work, boost the vinegar up till it does.
CM
Old Sep 1, 2004 | 10:51 AM
maximadave's Avatar
I'm talking about water spots on red paint. You can use vinegar on paint?
Old Sep 1, 2004 | 12:01 PM
Adrian's Avatar
I used it after washing my car and as im drying it i spray it 1oo% non-dilluted and ive done it more than once on two cars and it does work good and no damage. I also used the vinager str8 up 100% as a clay lubricant as im claying the car
Old Sep 1, 2004 | 02:31 PM
Bman's Avatar
Yes you can.
Are these mineral deposits, or damaged paint?
If vinegar proves to be ineffective, or you look at it carefully and it really looks like rings IN the paint (and it's not raised like junk on top of the paint) then you'll need to polish out the damaged paint. A scratch remover is usually a good place to start.
Keep the car well waxed.
Old Sep 2, 2004 | 09:01 AM
maximadave's Avatar
its a brand new 350ZR. The paint is in very good shape it just has water spots on the paint from sitting next to a sprinkler.
Old Sep 4, 2004 | 09:33 AM
PrinzII's Avatar
OG and counting...
dave: The vinegar would definitely be the best bet. You can use the 50/50 mixture to remove the water spots and then follow up with polish and then wax.
Old Sep 15, 2004 | 10:15 PM
hadman's Avatar
I use Mguiars "Quick Detail" for imperfections on a relatively clean car that doesn't need a wash. It should work well on water spots.
Old Sep 16, 2004 | 11:06 AM
schmatt's Avatar
Tell her to park away from the sprinklers. But if she can't, you are going to have to use some quick detail spray to clean the car every time it has water spots on it. You don't want to let them sit on the paint. The longer they sit, the more damage they will do to the paint.
trailer54
Nitrous
Nov 18, 2015 07:44 PM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
Hdnseek
Sep 9, 2015 05:55 AM
