1999 Maxima SE Amp/Headunit Install help
i just need to know a few things. Which dash kit is needed for the headunit install if needed at all. Where should i ground the amp to once everything else is done. and where should i run the power through, i think theirs a rubber grommit by the power steering pump if im not mistaking i just want to confirm this. And if theirs anything else i should need to know feel free to tell me asap thanks. My friend said that he grounded the amp to one of the bolts underneath the seats. Would some one be so kind and tell me how to remove the seats step by step thanks.
if i remember right there's a grommet to the left (standing in front of the car) of the master cylinder on the firewall. i ran the power wire through that under the carpet to the trunk. as for how to remove the back seat all you have to remove is the piece you seat on there's 2 tabs that you pull forword on about calve high when your seating on the rear seat one on each side. just pull them forward and lift up
what about the headunit the kid didnt tell me if he has the bose stereo so im not sure if he does or not if anyone could tell me what is needed for the bose system and without the bose system that would be great.
Originally Posted by DcMaN
i thought there was a rubber grommet i could just slide the wire through ?
Dman1989
19
Aug 17, 2015 03:44 AM
Team STILLEN
Aug 10, 2015 04:29 PM
MikesChevelle
Aug 6, 2015 11:36 AM
