Soft popping noise while turning the steering wheel?...
As mentioned in my other post, the knocking I heard while going over bumps has been fixed. But I get this soft popping noise when turning the steering wheel (like parking lot maneuvering). It seems to be coming from the passenger side...
Anyone else experience this that could give me some advice? I'll probably jack the car up and see if I can't source the noise while someone else turns the wheels...
While I'm asking for advice, there is another noise that is only typically heard while at idle. If feels like it's vibrating through the A/C lines. Maybe the A/C clutch is messed up (A/C works good)? Maybe something just a bit loose? But it goes away above 1000 rpms or so...
Thanks for helping a newbie out. I'm good with working on cars but as mentioned before, I just got this max and it's my first so my experience is limited with it. I can usually troubleshoot and fix these types of problems with my lude but that's because I know if inside and out now (engine swaps, tranny and clutch swaps, countless other stuff replaced...this is my play car so it gets beat on at the track quite often!
That noise is your strut bearings for sure. They are about $18 each (you need two, one for each side) from Nissan. I didn't replace mine, but I repacked them with regular axle grease. You can pry the bearings apart into 3 pieces. I filled that puppy up with grease, snapped it back together and haven't heard a peep from them in almost 100,000 more miles.
to check your strut bearings you can jack up the car. then turn the wheel in the same manner. If the noise goes away its your strut bearings because you will get noise when they are under load.
Also while the car is up check your axle boots. A worn CV joint can make that noise too.
Good luck
Good luck
Yeah, I would check for a CV joint personally.
I mean, I am sure it would be a good idea to check what mzmtg says.....he knows his crap.....also.
I am going to have to do this coming up.
I just looked at my driver's side wheel well the other day and there is grease everywhere in there. I finally found the source.......I have a torn CV Boot. That just means it is a matter of time before the joint goes bad.
Anyway, try those two things and see what is up.
If he is talking about what I think he's talking about, it's not CV joints.
CV joints that are bad only make noises while the car is rolling. Bad strut bearings will pop while the car is stopped and you turn the wheels side to side.
Just for the record I didnt say it was NOT the strut bearings.
Likelyhood is that it is most likely the strut bearings. But that's not the only moving part when you turn your wheel. keep that in mind.
It just might be a bad rack. Or something as cheesy as a noisy ball joint or tie rod end.
We make guesses here based on our experience. lets be fair to everyone
Thanks for the replies guys. My CV's are good (no broken boots though the outer pass side boot, while in good condition, looks to be a bit malformed or something. Instead of it having look like an accordian or whatever, it looks like it's pulled/stretched). But the popping is not while I'm moving so it's not the joint itself. Maybe the boot just stretching to a different side.
But for the strut bearings, where are they? Are they in the upper strut mount? I didn't replace the pass side.
Also, I've never heard of strut bearings. Sounds almost like it should be up there with cross drilled brake lines or muffler bearings!
lol
lol
Originally Posted by LudeAEM
Hey interlude dood.
I think we're one of the few people with ludes in our screen names. And there others are most likely right,.... its the strut bearing. Mine are starting to go out too.
I think we're one of the few people with ludes in our screen names. And there others are most likely right,.... its the strut bearing. Mine are starting to go out too.I have to admit to everyone though, this is the most enjoyable daily driver I've owned to date. I haven't owned anything to spectacular (97 Accord, 97 Civic, 99 Suburban, 88 Prelude <- unmodded, 85 Grand Am, 90 Isuzu Pickup <- modded...about even) but still. Not bad for a mere $1500!
Good call.
Originally Posted by MadChef
Originally Posted by 96pearlmax
Sounds like its the struts...Check for grease up in the wheel well..If there is, you torn your CV boot
Trust but verify...
Replacing the strut bearing is a popular suggestion, but I had the same problem and solved it by replacing the right-side swaybar endlink bushing. The strut bearing was NOT defective. What made diagnosing the problem harder was that I couldn't reproduce the sound with the car jacked up. I needed there to be a load on the control arm et al, THEN the noise made itself known.
I suggest using the rubber hose trick to find the sound. When parked with the engine running, have someone cut the steering wheel back and forth. While they are doing that, hold one end of the hose to your ear and point the other end at the various suspension components that could be making the noise (ie, strut bearing, endlink bushing, tie rod ends, etc.) You should be able to tell pretty quick which part is making the noise.
Good luck!
TOM
Good luck!
TOM
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
