How to remove the ECU?
Old Sep 2, 2004 | 05:52 AM
danbortz's Avatar
hey guys...
my check engine light came on the other day and i wanted to run the self diagnosis to see what the problem was and i couldnt find the screw in the ecu!
i've read posts saying that the bracket the screw is on might have broken off and be inside the ecu and was possible to remount it.
i removed the 2 small bolts on the front and back of the ecu (with a 6mm wrench i believe, but dont quote me on that) but the whole unit wont slip out.
What else do i need to do to remove the unit? Anyone have any other suggestions that could help me out?
I'm going to get the CEL codes from an Autozone ODBII scanner so i can hopefully fix those in the mean time, but i'd like to fix this so i can check the codes on my own in the future.
Thanks in advance!
Dan
Old Sep 2, 2004 | 06:47 AM
chuckie311's Avatar
the 99 you cant see the screw you have to use a very small phillips . you dont have to break the break there is aplastic cover over the screw you just have to ull it back or poke a though it
Old Sep 2, 2004 | 06:52 AM
sagamax's Avatar
Give me a Bud Light Holmes
what u mean by self diagnosis???
are you just trying to check your codes....if so you dont need to remove the ecu.
Old Sep 2, 2004 | 10:00 AM
danbortz's Avatar
i want to check the codes from my CEL, but the screw inside the ECU is gone. when i use a philips screwdriver to get the codes the screwdriver goes handle deep inside the ECU.
Thats why i'm assuming that the screw is lost inside the ECU.
Old Sep 2, 2004 | 10:20 AM
sagamax's Avatar
oic yeah there are 4 screw that hold the ecu i would use a socket to take it out i forgot what size it is either 10 or 12 its a pain to get to but not impossible
Old Sep 2, 2004 | 12:14 PM
joew's Avatar
I have unplugged the gray connector on the ECU. do you folks know how to pop off the white plastic box? i need to open it.
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
