Why my car didn't pass emissions...HELP...
Old Sep 3, 2004 | 05:12 AM
MaXtUneD's Avatar
15 MPH Test: Passed the CO barely..3 more points, I would of failed..
My NOx levels were high as crap..double the amount of the legal level...
25 MPH test: Failed all three..again, my CO level failed..It was 2 points passed the legal level..My NOx levels were same results, double the amount..
I have a turbo VE..92 Maxima SE..
Mods are Walbro High flow pump, Cartech FMU, 2 step colder copper ngk plugs, high flow catalytic convertor3 inch exhaust..everything else is stock like injectors, etc...
I checked my egr valve to see if its working and it is..I read that it helps bring your NOx levels down..I want to say my Catalytic convertor is failing but I just go the car down last december....its only been 7 months with the turbo kit..
Any help will be appreciated.
thanks
Maxtuned...
Old Sep 3, 2004 | 05:48 AM
Shadow's Avatar
Perhaps the car isn't tuned? The Walbro and FMU will both make your car run on the rich side. Emissions would be high even with a functional cat.
Old Sep 3, 2004 | 06:28 AM
MaXtUneD's Avatar
oh ok....
One question though, I thought the FMU kicks in only when in boost.?????
And my thought is even with my walbro fuel pump, I still have the stock injectors, so wouldnt the injectors be delivering the same amount of fuel even if my car was not turbo'd but with the walbro fuel pump??
Old Sep 3, 2004 | 10:57 AM
subs1000w's Avatar
Originally Posted by MaXtUneD
oh ok....
unless you have an ajustable FPR your FP will be higher with the walbro so your stock injectors will be delivering more fuel than stock
Old Sep 3, 2004 | 05:53 PM
MaXtUneD's Avatar
yeah..I was thinking about that also..would a fuel pressure regulator solve my problem if I brought down the fuel pressure to stock level which is around 35-40 psi right???
Old Sep 3, 2004 | 09:00 PM
subs1000w's Avatar
whats fuel pressure at now at idle and wot
Old Sep 4, 2004 | 04:22 AM
MaXtUneD's Avatar
idle is around 48-50 psi..somewhere around there..dont know at WOT because the gauge is in the engine bay...but i bet its high though....
Old Sep 4, 2004 | 08:51 AM
subs1000w's Avatar
to check WOT FP just unplug the vacum hose going to the FPR
regardless of wot fp thats really high for idle i could definitly see that affecting emissions
Old Sep 4, 2004 | 01:57 PM
Lonely Driver's Avatar
lFirst thing you should do is change out your high flow cat. They suck at reducing emissions.
Old Sep 5, 2004 | 05:57 AM
MaXtUneD's Avatar
so...what FPR should I get????
also, does the gauge have to read 0-100psi??
Old Sep 5, 2004 | 09:06 AM
MaXtUneD's Avatar
come on guys..i need your help
Old Sep 5, 2004 | 09:24 AM
stephenlc's Avatar
they should give you printout and what you failed.
Old Sep 5, 2004 | 10:30 AM
MaXtUneD's Avatar
they did..look at my first post.
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
altome15
Aug 10, 2015 07:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
