compression on my motor
Old Sep 16, 2004 | 10:27 AM
95turbo gxe's Avatar
Ok I took the time to do a check and this is what I came up with.
the haynes fsm says that normal would be 173psi
the min is 128psi
and the maximum diffrance between cylenders are 14psi
cylender 1= 177psi
c 3= 177psi
c 5= 180psi
c 2= 177psi
c 4= 155psi
c 6= 177psi
ok I got 165,000 miles on my vg and use no oil and no noise
just that cylender #4 is got me wondering if I will be ok for boost
tell me what you all think. Oh yeah im thinking some where around 5psi at first then ty to go to 10 or 11psi of boost
Old Sep 16, 2004 | 11:33 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You might try digging a little deeper with a leakdown test on that cylinder #4 or at least drop in a couple drops of oil and then try doing the compression test again. Search on the net for many more things you can do to try and narrow down exactly what's different with that cylinder.
I say go for it though, just expect to do a motor swap someday so prepare in advance. I wouldn't worry much though.
Old Sep 17, 2004 | 01:23 PM
Bags's Avatar
VG Ridah's Biatch Hoe
the min is 128psi
cylender 1= 177psi
c 3= 177psi
c 5= 180psi
c 2= 177psi
c 4= 155psi
c 6= 177psi
There is no real answer here. Alex gave you some good opitions. Plan on tossing in a new engine if your thinking about ~10 psi. But, like Icy said, confirm some stuff on #4 before you do anything else.
Old Sep 18, 2004 | 01:39 AM
96_vqmax's Avatar
Hey guy,my friend have a leak down test with 2 gauge on it that he bought used,but it doesn't come with the manual,so how do you use it and how do you read the gauge?Thanx alot for your help.
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
