10 PSI Pulley?? 3.25" or 3.125"?? HELP
Any maf changes
Running that 3.25 pulley did you ahve to make any changes to your fuel system other than the ones that the stock supercharger had you change. Such as fuel injectors, maf upgrade anything like that. What do you think you 0-60 speed is?
Originally posted by SprintMax
my 3.25 pulley gives 9 - 9.5 lbs of boost
Re: Any maf changes
if anything id think it would be EASIER to find injectors for the 2k cause their top feed injectors and those are more widely used. its harder to find injectors for the 4th gen, i couldnt find any 440c's so ended up going with 370cc off ythe 300ZX.
Mikey, hell yea! the Nismo 550cc injectors are like 1600 retail. set of 6. sucks! Nissan lists the 300ZX injectors for like $230 EACH. i refrained from saying "side feed" injectors cause i was corrected about that last time, heeh, i still think its called side feed tho.
The factory 4th Gen 239cc injectors are side feed, but that won't make top feed injectors for this application any easier to find. I would worry about re-programming the 2000/2001 ECU before I spent $1,000 on injectors. It would suck to buy those parts then not have anyone that can re-program the ECU....
Don
Don
Well I remember someone telling me (Don?) that 9-10 psi is do-able with just an intank fuel pump...That true??
I'm getting a 255lph intank fuel pump...
I planned on 10psi but if thats too much maybe i'll do slighly less...like maybe 8psi or so...
I just want to change the pulley while everythings pulled apart AGAIN cuz i threw another belt...
ANYONE with experience using different size pulleys please give me the scoop!!
Thanks.
Thanks.
Does the super charger force the injector duty cycle to max, 100%? Or does it stay around normal, 70%? You may be able to get more juice from an AFC by opening the duty cycles a bit. And I think Steve from Chicago was saying he runs about 70psi FP with his set up, I dont know how much boost he has though. So you should have a bit more room with pressure too.
And you said it's not for you
Thanks.
Thanks.
rbarnes
Dec 31, 2015 06:29 PM
