nozzle install question
Old Sep 20, 2004 | 09:58 AM
chancy31's Avatar
When I drill the hole to install the nozzle does it need to be behind or infront of the little sensor that measures intake temp? I thought that it might need to go behind so the ecu will send more fuel because the nitrous will be cold when it passes the sensor. thanks
Old Sep 20, 2004 | 01:10 PM
SonicDust187's Avatar
The nozzle should be after the MAF sensor and as close as possible to the Throttle body.
Old Sep 20, 2004 | 04:59 PM
TAPOUT's Avatar
You will lose
Usually the nozzle should be within 4 inches of the TB. I have mine about 1/2 inch after the temp sensor.
Old Sep 21, 2004 | 09:59 AM
chancy31's Avatar
The order of my setup is MAF, Nozzle, then the temp sensor. I think I should change it because spray just isn't making much difference, i think the bottle was pretty low (a friend lent me his) I filled it yesterday and plan on going to the track saturday night.
thanks for any more info.
Old Sep 21, 2004 | 12:14 PM
What temp sensor are you guys talking about?
Old Sep 21, 2004 | 07:43 PM
TAPOUT's Avatar
You will lose
The one that is 4 1/2 inches in front of the TB.
Old Sep 21, 2004 | 07:53 PM
You mean the maf sensor.
Old Sep 21, 2004 | 07:58 PM
On my fed spec I only have one intake temp sensor , filter, maf, midpipe then tb. I guess 99 and CA spec have an extra intake sensor.
Old Sep 21, 2004 | 08:36 PM
TAPOUT's Avatar
You will lose
Yeah, I have a sensor on the underneath of the midpipe, between the MAF and the TB. I'm pretty sure, but not positive, that it is the temp sensor.
Old Oct 4, 2004 | 03:18 PM
russianyuri's Avatar
don't put the nozzle too close to the throttle body because I've seen many-a cars freeze the throttle body in the wide open throttle position and run their cars off the road
Old Oct 4, 2004 | 05:05 PM
maxima98vspec's Avatar
mine is right next to the sensor so about 4 to 5 inches from the TB
Old Oct 4, 2004 | 05:06 PM
Originally Posted by russianyuri
don't put the nozzle too close to the throttle body because I've seen many-a cars freeze the throttle body in the wide open thorttle position and run their cars off the road
yea it has to be min of 6 inches from the TB plate
Old Oct 13, 2004 | 07:16 PM
tampamax's Avatar
Oh geez
Old Oct 15, 2004 | 08:03 PM
akadiablo's Avatar
OK people, I am wondering since i have a short ram intake like on ebay for my max, should i put the nizzle in the rubber boot that goes between the MAF sensor and the mid-pipe??? Or should i drill and tap as far away as i can get without going into the rubber boot, so that the nozzle is in the mid-pipe????? It is a Zex Wet kit.... Also what size of shot should i run to be safe around town screwing around.. As compared as to what I can run at the track on a basicly all stock motor???
Old Oct 15, 2004 | 11:43 PM
Jime's Avatar
Put it in the midpipe, the rubber boot will do a lot of flexing when hit with a 1000 psi of nitrous.
Stick with the stock jets (probably 75 and lower) until you get more familiar with the system and know what your pump etc is capable of.
Even a 35 shot is a real kick in the shorts.
PS I had one setup where I drilled the TB and installed the nozzle so thats BS about the throttle freezing. I usually put it so the nozzle is pointing up with the lines going down to make it less visible but its easier to change jets if it points down a bit so when you remove the line the jet stays in the nozzle vs falling out and getting lost if you aren't careful.
Old Oct 20, 2004 | 12:35 PM
1000psi ? Blow-torches usually get it to 1200psi no-prob... talk about a "HIT"
PH98I30
Jan 9, 2025 08:08 AM
jchronis2552
Aug 13, 2015 07:48 AM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
