Open Vacuum Line - Assistance Reuested
Old Sep 21, 2004 | 05:38 AM
Turbobink's Avatar
Open Vacuum Line - Assistance Requested
Look near the center of this photo...
There's an open brass vacuum line.
Is this supposed to be connested to something or should it be stoppered?
I hope the link works...
DON'T BOTHER CLICKING THIS. THIS LINK DOES NOT FUNCTION. HOWEVER, THE LINK POSTED IN THE SECOND REPLY BELOW WORKS.
Old Sep 21, 2004 | 06:17 AM
s0ber's Avatar
link dont work...
http://pifiu.com/upload/
upload ur pic there.
Old Sep 21, 2004 | 08:24 AM
Turbobink's Avatar
Does this work?
http://www.pifiu.com/upload/uploads/...20Line%201.JPG
Old Sep 21, 2004 | 12:55 PM
njmaxseltd's Avatar
You throwing and codes? There definately should be a line attached to that.
Old Sep 21, 2004 | 12:58 PM
Turbobink's Avatar
CEL is on.
Code is 0302 = EGR High/Low flow
Old Sep 21, 2004 | 01:16 PM
99se5spd's Avatar
mine it looks like it goes into the tb under another larger hose. in the pic its behind that vent tube from the intake
Old Sep 22, 2004 | 05:00 AM
Turbobink's Avatar
Can I get a photo, a clear explanation, or even a vacuum diagram?
I inspected the TB area and am unable to locate a vacant fitting or loose line/tube.
Old Sep 22, 2004 | 07:38 AM
Nealoc187's Avatar
SLOW
is that line connected to the center tube of 3 tubes coming off the lower part of the throttle body? if so I was having a discussion about that line the other day with I30tMikeD. his isn't connected to anything while mine is connected to a small nipple on my intake midpipe.
Old Sep 22, 2004 | 08:23 AM
Turbobink's Avatar
It's not the center line.
It's the far left one (the forward-most one). It's nearest the intake baffle/resonator.
If you look at and enlarge the photo you'll see that the center line is connected to the intake or TB via a black rubber hose and the far right line (the rear-most one) is stoppered with a black rubber cap.
With the car running at idle, this open line draws no vacuum so if it's supposed to be hooked up, it obviously gets drawn upon.
On the other hand, maybe the vacuum this line draws doesn't come on until RPMs rise.
Old Sep 22, 2004 | 10:02 AM
Nealoc187's Avatar
SLOW
i took 2 pictures of the part that hose goes to with my camera phone. i do not know the name of the part, and i cannot find a picture of it in my Haynes manual, but hopefully it will be of some help. i am uploading them now i will post the pics in a few minutes.
Nealoc187's Avatar
SLOW
btw there is a vacuum diagram on a sticker on the underside of your hood if you want to check that out.
Old Sep 22, 2004 | 10:13 AM
Nealoc187's Avatar
SLOW
Here's two pics of it. The line in question coming that is the left (driver's side) of the 3 identical fittings coming off the underside of the TB is the line you see on the top of the round black thing I'm pointing at, coming off towards the right (opposite of my finger).
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
