anyone change the axle seal on their max?
i got a 92 ve spd and when i changed the tranny fluid i noticed the axle seal was leaking a bit. is there any "how to's" on changing the axle seal? anyone else change theirs? was it hard?
yes many times. seal replacement is the same regardless. make sure you get the correct seals for a VE30DE 5-sp. I highly suggest buying a seal puller and if you think you are going to be doing much seal replacement, a seal installer kit. but if you are carefull, you can tap it in STRAIGHT!
Originally Posted by -shock211-
if you don't want to buy any extra tools, use your old seal to tap the new one in straight.
Have you tried that? That seems like one hell of an idea for the larger seal. That one is huge pain to drive in straight. Does it just "drop" in w/o any tapping?
Originally Posted by Brad92SE
This is definately the way to go if you dont have the tools. Also, you can put the new seals in a refrigerator/freezer for a bit so that they contract and go in a little easier.
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
carlosvq30
Aug 17, 2015 11:32 AM
RealityCheck
Aug 5, 2015 06:18 AM
