how much do coil packs cost? what does infinit resitance read?
Old Sep 22, 2004 | 11:25 AM
multiplexor's Avatar
Hey guys...
I was measruing my coil packs and i'm getting different resitance values for each coil pack?!?!?!
how do i know when they might be completely dead? when they have a high resitance value?
I'm assuming infinite resistence means that i should see a zero value on my multimeter when i read the coil packs values?
Thanks guys!!
Old Sep 22, 2004 | 11:37 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
infinite resistance is 1. if your getting like 1000 + or - then its not functioning properly.
they cost $55 from www.jrnissan.com use "Maxima" promo code to get 25% off.
Old Sep 22, 2004 | 12:47 PM
ah ok... cool... yeah one pack gave me 450ohm when reading pin 1 and 2...
another gave me 85.8...
i assuming the coil is more dead the more the resistence value goes up?
Old Sep 22, 2004 | 12:58 PM
killcrap's Avatar
could really tell you. if you get a resistance other than 1, then you should replace it. your car will hesitate over time, and after that happen's then i believe your fuel injectors may go as well. since your replacing your coil, you might as well order some NGK copper Spark plugs. and replace them as well.
Old Sep 22, 2004 | 01:08 PM
Coolies! Thanks a mill
I kept wondering what an infinite resistance would look like... hehe
But yeah, hopefully this will fix my idle problem... ( rough idle, sometimes stalls randomly... other times the car is strong as hell in the low end...)
aminus21
Sep 12, 2015 04:53 PM
2kmaximel
Sep 10, 2015 08:13 AM
crazyespn
Sep 3, 2015 01:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
