what brand to replace my warped rotors with???
It's time to replace the oh so common warped rotors on my 2k2 max. I do not want to buy factory replacements as they seem to warp w/i six months to a year according to the other war stories on this model.
My mechanic tells me that the chinese made rotors warp easily and I should go with more expensive american made. Not sure what brands are American made. For some reason the "Brembo's" which are made in Italy seem to be mentioned in most sport's car forums. The question is for you all who've upgraded from factory rotors, which rotors/pads did you go with and would you buy them again?
Thanks for the input
I want to hopefully buy 'long-lasting' brake rotors.
No such thing as long lasting but, the aftermarket ones will last longer than stock but eventually will warp. Brembo makes a good rotor.
Carefull driving and good break in will make them last longer, and avoid puddles after braking.
i know frozen rotors are great, but they are pretty expensive..... a friend on the org gave me this website for 2003 BREMBO BLANKS for 56.99 each. Its pretty good IMHO.
link is - http://www.importrp.com/catalog.php?...s&subcat_id=11
I have one question though, the front would wear more, so can i change the front rotors then the rear later.... or should i just change them both at the same time?
change the front only! no need to change the whole system. Rear's last atleast twice as long. thank mr.frontwheeldrive.
I also picked up a set of front and rear x-drilled and slotted black zinc coated rotors from www.iRotors.com. No complaints as of yet (1k miles roughly).
Originally Posted by Triple8Sol
Got mine from "maxed up" here no the .org. Cross-drilled/slotted. Got a pair for not much over $100. Pics on my cardomain...
Originally Posted by Qmax03
cant seem to find rotors for 03 max on irotors
Hey triple, can you give me that persons contact info. I actually want to get a pair of front 2003 rotors. Slotted only though.
I want to hopefully buy 'long-lasting' brake rotors.Keep in mind, it is not that the rotors actually warp, the problem is material from the pads transfering to the rotor and fusing there. If you get higher temp pads, that problem is reduced as well.
I went to Hawk HP pads with brembo blanks and I have been very happy even for the occasional autocross.
Originally Posted by Ben
Pad selection is at least as important as rotor selection.
http://www.stoptech.com/whitepapers/...otors_myth.htm
I just installed Hawk HPS with OEM rotors in my '02. Right now it feel great but I have to wait and see how this combination performs in the long term.
All his styles of rotors are listed on his cardomain right here:
http://www.cardomain.com/memberpage/342829/2
Tell him I sent ya
03VQMAX
Sep 25, 2015 04:19 PM
Maxima_no_more
Aug 15, 2015 05:37 AM
RealityCheck
Aug 5, 2015 06:18 AM
