Can Crankshaft position sensor results no start?
Old Sep 28, 2004 | 08:43 PM
byf's Avatar
byf
My 97 maxima can crank over but no spark.
The mechanics said the crankshaft position sensor located
close to the oil filter might need to replaced.
I wonder if it's true that the crankshaft position sensor can
prevent the car from start.
Old Sep 28, 2004 | 11:02 PM
f550maranello2's Avatar
u get no spark check the engine ground
Old Sep 28, 2004 | 11:50 PM
jcy98maxse's Avatar
Turbo is too much fun!
cps can make ur car not start, check both the one on the timing cover and the one on the tranny....
Old Sep 29, 2004 | 09:15 AM
95MAXIMASExy's Avatar
hah, my 95 has the hard starting problem sometimes too. when it would take quite a bit of effort to start sometimes the check engine light would go on, after pulling the code numerous times it was always the crankshaft position sensor (REF) ---- the one by the oil pan. I thought hmm maybe if i replace it it will start. wrong answer. i replaced it and it still pulls the code, and im out about 80 bucks. this sensor is not the reason why the car doesnt start but is set off when the car doesnt start easily. hope this saves you 80$
-Tanner
mvm062
Nov 30, 2020 09:00 AM
sake1bs
Sep 19, 2015 09:32 PM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
