that black thing in the trunk...
Old Sep 30, 2004 | 10:34 AM
tripleGmax's Avatar
So there was thread a while back about the thing that sits under the trunk carpet directly behind the rear seats, but i cant find it at all. So does anyone know what it is or what it does? OR can i just take that thing out.
Gregg
Old Sep 30, 2004 | 10:37 AM
«§»Craig B«§»'s Avatar
nothing too important, go ahead and take it out
Old Sep 30, 2004 | 10:39 AM
Scope's Avatar
Im izz sexay
You have an SE so you won't know about it.
Old Sep 30, 2004 | 10:45 AM
tripleGmax's Avatar
know about what?
Old Sep 30, 2004 | 10:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by tripleGmax
know about what?
the GPS locator inside of it.
Old Sep 30, 2004 | 10:49 AM
Jeff92se's Avatar
I'm needing a caw
Keep looking.
Gregg
Old Sep 30, 2004 | 11:04 AM
tripleGmax's Avatar
alright ill just take it out.
lose the weight
Old Sep 30, 2004 | 11:05 AM
tripleGmax's Avatar
keep looking for what???
Old Sep 30, 2004 | 11:13 AM
Scope's Avatar
Im izz sexay
SE's didn't come with those. It's a GXE thing that weighs about 20 lbs. It's usless. These guys are just messing around with the Newbs.
Old Sep 30, 2004 | 11:43 AM
4dscPat's Avatar
Big rubber useless thing in the trunk of GXEs. As far as I an tell, it's main function is to make your car heavy and slow.
Old Sep 30, 2004 | 12:23 PM
anaximander's Avatar
20lbs more in the trunk will make it neither heavy nor slow (which the gxe already is). If anything, it'll minimally correct the understeer bias.
Old Sep 30, 2004 | 12:53 PM
DanNY's Avatar
Ad·min·is·tra·tor
YES!!!!!!...1st answer that made sense.
Old Sep 30, 2004 | 01:40 PM
Tarzan's Avatar
But how on Earth it will achieve that consistently with any combinations of load in the trunk, on the floor and with the people on the seats? There is no way that weight can serve as a correction under all circumstances! Only under some...
Old Sep 30, 2004 | 01:43 PM
Scope's Avatar
Im izz sexay
Also in that case why is it only found in GXE's. If you wanted to correct such a problem then why not give it to the sportier SE maxima's.
Old Sep 30, 2004 | 01:49 PM
Jeff92se's Avatar
I'm needing a caw
Because it doesn't and it's purpose is to dampen noise.
Old Sep 30, 2004 | 02:10 PM
Because it's not in there for that purpose, but like jeff said to dampen noise. They delibarately produce the cars with an understeer bias for safety purposes (let alone the fact that fwd's are naturally understeering). That's why I said "minimally" meaning you won't notice it; adding any weight to the rear will correct understeering but only to the extent of its mass.
Old Sep 30, 2004 | 02:13 PM
Jeff92se's Avatar
I'm needing a caw
Are you sure? Imagine if you load the rear with a really heavy weight. ie.. huge speaker box etc.. Then imagine if you took out a large amount of weight. You think adding weight would make the rear oversteer more or less? Making the rearend very light would tend to make it more slide happy IMHO. ie.. a truck
Because it's not in there for that purpose, but like jeff said to dampen noise. They delibarately produce the cars with an understeer bias for safety purposes (let alone the fact that fwd's are naturally understeering). That's why I said "minimally"; adding any weight to the rear will correct understeering but only to the extent of its mass.
ChrisCheezer's Avatar
- "Dont take it out!! your rear end synchronizers will fall out of wack!" (remember that one??!) scared the sh*t outa me
Old Sep 30, 2004 | 02:28 PM
goon9's Avatar
Anyone wanna sell me thiers? I have big black mass envy.
Old Sep 30, 2004 | 02:30 PM
DanNY's Avatar
Ad·min·is·tra·tor
ummm they have it in the SEs also...
Old Sep 30, 2004 | 02:36 PM
Kikcaffine's Avatar
Yea, mine has it and its an Se, so NAHH!
Old Sep 30, 2004 | 03:17 PM
eeeeeeeeewwwwwwwwwwwwww thats sounds really gross.
Old Sep 30, 2004 | 03:23 PM
goon9's Avatar
I kidd I kidd
Old Sep 30, 2004 | 04:11 PM
bobbydigital450's Avatar
hahaha...i think the best one i heard on a previous thread was "its a prehistoric twinkie"
Old Sep 30, 2004 | 04:29 PM
Kikcaffine's Avatar
Twinkies never good bad, duh so it couldnt be!
Old Sep 30, 2004 | 04:34 PM
Greeny's Avatar
¯\(°_o)/¯
Is everybody drunk tonight!!
Old Sep 30, 2004 | 04:35 PM
We had this discussion in my rear parallel links thread (can't search). One would think that little weight in the rear would make the rear end slide out easier, but unless you have a really stiff rear suspension it will be a hard-to-control slide out with the corresponding speed loss. I came to this conclusion through a few close encounters with the ditch. Adding rear weight to such a car will make the rear end slide out harder, however it will reduce the understeer itself and balance out the car more, i.e. less plowing in a curve.
Old Sep 30, 2004 | 05:57 PM
Scope's Avatar
Im izz sexay
Hell with that black thingy just add some dynomat and get some suspension mods.
Old Sep 30, 2004 | 07:36 PM
Maximan190's Avatar
thats why gxes are so slow because of that thing in the trunk, just remove it then youll have more power
ps.. this topic is beatin mad dead horses
adamgalazka
Feb 5, 2023 08:24 AM
ballerchris510
Sep 10, 2015 09:35 PM
doctorpullit
Sep 10, 2015 06:33 PM
03VQMAX
Sep 5, 2015 03:47 PM
A32goldylocks
Sep 2, 2015 06:39 AM
