I won't be spraying for a while....
Old Oct 6, 2004 | 11:03 AM
TAPOUT's Avatar
You will lose
I now realize why I only ran 13.7 at the track on Sunday. I was only using 5 cylinders. I either bent a valve, or lost a ring or piston. Not sure yet, I will know either tonight or tomorrow. I only have 75 psi in cylinder 1. I had a check engine light on after my first run at the track, but thought it was due to putting in too much race gas, or something silly. I guess it is time to rebuild.
Old Oct 6, 2004 | 11:26 AM
maxima98vspec's Avatar
that sux bro...that y u have a spare motor sitting around so u can swap
Old Oct 6, 2004 | 11:57 AM
RichP23's Avatar
Ouch! Sorry to hear that. Good luck.
Old Oct 6, 2004 | 06:59 PM
TAPOUT's Avatar
You will lose
Getting a motor from Redmax, hope to be up and running soon.
Old Oct 9, 2004 | 12:06 PM
95maxrider's Avatar
Lightly modded
Damn Jason, that's terrible. How many miles were on that motor? Any idea of what would have caused this? You think it happened even before you set up the 2 stage? Any plans to build up the new engine?
Old Oct 13, 2004 | 07:12 PM
tampamax's Avatar
Don't be to hard on yourself. The number one cylinder is prone to go lean mearly by the design of the manifold. Seen it happen in a few engines on the max. The problem is that the number one runner opens up way before the others do, thus its much easier for the air to take the path of least resistance. Were you running higher than a dry 100 shot? To remedy this occurance either go wet or direct port if you plan on consistantly running over 100 shot. Or you could make sure you point the spray fan so it disperses(sp) in a vertical pattern and aim the shot to the very back of the neck of the mani were it begins to turn to connect with the rest of the runners.
On a side note....nick you get your system hooked up yet? Damn nice looking car.
Old Oct 13, 2004 | 11:50 PM
95maxrider's Avatar
Lightly modded
Oh, all the lines are run. I should be getting my ECU back from JWT in a few days, then I need to get the MEVI installed, then I'm good to go. I can't wait.....
Old Oct 14, 2004 | 06:20 AM
tampamax's Avatar
That's great to know! I know how that waiting can get to ya. Have fun with it bro. And remember if you ever have some questions to hit me up.
[/highjack]
Old Oct 14, 2004 | 11:03 AM
95maxrider's Avatar
Lightly modded
Thanks man. You've already been a great help to me, but I'm sure I can think up some more questions to ask!
Jason- Any news on when your getting the engine installed? How many miles are on it? Plans on building the old engine?
Old Oct 14, 2004 | 12:01 PM
Jason R's Avatar
aka UNCDooD
he's going to pull off the front head first and see if its just a bent valve. I was up there yesterday dropping off a set od stock heads.
Old Oct 17, 2004 | 06:52 AM
TAPOUT's Avatar
You will lose
I bought a second car, and plan to start the work after getting it tagged. I believe that it is a bent intake valve, and not much more than that. I have over 128K miles on the car, and have been running it pretty hard for the last 50k. By the way, the second car that I bought is an all motor low 11 second Mustang that just happens to be set up for the addition of a 200 shot. Oh, and I am running wet shot at 125, but dry at 80. I think what happened is in my haste to set up the second stage at the track, I hard wired the switch for stage 2, and I forgot to turn the switch off before I let off the gas. I did it backwards because I am so used to having it turn off automatically. I learned that lesson, and hope to be back with the car soon. I don't think the Mustang will do too good in the snow. Nick, let me know when the stuff comes in, I want to finish up your car and take a ride with the computer. Then I'll scare you in the Stang.
Old Oct 25, 2004 | 10:19 PM
Import Roller's Avatar
another problem brought on by N2O. I've been there already, it sux. luckily, I got a 240sx a few weeks later because of it, so i had a car to roll. and that 240 was way more fun to drive
Old Oct 26, 2004 | 07:09 AM
tampamax's Avatar
Yey Another bandwagooneer.
Old Oct 26, 2004 | 11:48 AM
the 240 was before the bandwagon really hit. i sold the 240, i just have the altima now
Old Nov 3, 2004 | 12:45 PM
TAPOUT's Avatar
You will lose
Well, I pulled the head, and the good news is there is no hole in the piston, the bad news is that I don't see anything at all that could explain why this cylinder has stopped firing. I am almost starting to wonder if there was something else wrong. I checked the coil, injector, spark plug, and they all worked when I swapped them with cylinder 2, the problem didn't migrate. I checked this cylinder with a compression tester, and it only registered 75 psi, not 170 like the others. I am going to start the process of installing the new head that I got, and see if it fixes it. This is getting frustrating. Anyone have any thoughts of what it could be? Valves look okay and held WD40 when it was upside down, with no leaks.
Old Nov 5, 2004 | 08:12 AM
TAPOUT's Avatar
You will lose
Found the problem. Three big grooves in the cylinder wall. New engine time.
Old Nov 5, 2004 | 09:53 AM
SeaFoam2DMax's Avatar
Oh hi....
Old Nov 6, 2004 | 05:40 PM
95maxrider's Avatar
Lightly modded
So what does that tell you about what failed/went wrong?
Old Nov 7, 2004 | 04:44 PM
TAPOUT's Avatar
You will lose
Rings.......
Old Nov 7, 2004 | 06:15 PM
Jason R's Avatar
aka UNCDooD
that sucks Jason. sorry to hear that man.
Old Nov 14, 2004 | 02:40 PM
Luquire's Avatar
so how do your rings cause that bad of a problem to the walls of the cylinder. i mean was there just to much pressure on the cylinder its self or was there just a bad ring.
Old Nov 15, 2004 | 07:16 AM
Bluebird's Avatar
I am Roid Rage
Since you're gonna be replacing the block anyway, might as well go for the 3.5.
Old Nov 15, 2004 | 12:01 PM
TAPOUT's Avatar
You will lose
I might go for the 2K2 3.5. I am swapping Corey's old motor in the car right now, and when I'm done, I'm thinking a trade-up might just be in order.
Sep 27, 2015 08:37 AM
bumpypickle
Sep 19, 2015 01:07 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
