stripped NUTZ!!! OMG
Old Oct 10, 2004 | 12:25 AM
GLEtotehMAX's Avatar
I just got my y-pipe in yesterday and i went to install it, and i was able to get all the nuts broken loose EXCEPT for one which was being stubborn and we ended up stipping it. Is there anything i can do to get it off without having to take it to a shop? PLZ help
Old Oct 10, 2004 | 12:33 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Did you try using some form of penatrating spray?
Old Oct 10, 2004 | 12:34 AM
Prophecy1's Avatar
Liquid Wrench .. Or a drill
Proph
Old Oct 10, 2004 | 12:37 AM
yea i used a rust penatrating spray, but i guess it didnt help much for that one bolt
any other ideas?
Old Oct 10, 2004 | 01:04 AM
packetattack's Avatar
Its probably so frozen that you'll need a torch to try and heat it up. Get a small cylinder of MAPP gas from Home Depot along with a nozzle.
If that doesn't work, then you'll need to take it into a shop and have them torch it off with an acytelene torch.
any other ideas?
Old Oct 10, 2004 | 01:15 AM
i guess that ill got get some sort of torch in the morning and try that out. Thanks
Old Oct 10, 2004 | 01:38 AM
Maxtank's Avatar
We had to torch all 4 of my cat's bolts...
Old Oct 10, 2004 | 06:48 AM
99se5spd's Avatar
same thing happened to me and in the process we crimped the nut on with vise grips trying to get it off. torch did nothing. so what i did was very carefully grind a side off the nut with a small cut off wheel on a dremmel tool, carefull that you dotn go too deep and hit the threads of the stud. once i got it down pretty far i hit it once with an air hammer and voila.
Old Oct 10, 2004 | 06:56 AM
happyricefob's Avatar
V^___^V
which bolt are you refering to? the 14mm bolt under the rear header or the 14mm bolt on the cat?
if it's the bolt under the rear header, you should have use pivot socket to help you remove it.
if it's the bolt on the cat, you should have use a breaker bar to help you remove it.
Old Oct 10, 2004 | 09:52 AM
its the one on the cat. i was able to break all the ones on the headers loose.
Old Oct 10, 2004 | 07:07 PM
Ant96GLE's Avatar
Torch them, its more fun that way
Old Oct 10, 2004 | 07:10 PM
mendon99's Avatar
tastey wheat
will vice grips take them off? or maybe find someone that owns a dremel
Old Oct 10, 2004 | 07:15 PM
well earlier today i tried vice grips but that didnt help at all. SO tomorrow morning im going to take it to a shop and get them to install it.
Old Oct 10, 2004 | 07:29 PM
kraimer21's Avatar
dude, if you are like me and hate taking your car to the shop, go to sears and pick one of these, http://www.sears.com/sr/javasr/produ...id=00952160000
good luck!!
Old Oct 11, 2004 | 06:07 AM
thats pretty cool but i already dropped my car off at the shop this morning. And besides, my mom offered to pay for it, so its all good.
rbarnes
Dec 31, 2015 06:29 PM
RealityCheck
Oct 2, 2015 06:34 PM
maxima297
Sep 24, 2015 08:57 PM
steven4838
Aug 26, 2015 11:04 AM
