View Poll Results: What's better for the engine?
Voters: 39. You may not vote on this poll
what's better N why? Mobile 1 every 6,000mi, or regular oil every 3-4000mi
Has anyone seen the comparison of Mobile 1 versus Regular motor oil? Just wondering b/c I changed my oil with regular oil over the weekend and thought it would save lotta hassle if I put in extra <a href="http://www.ntsearch.com/search.php?q=money&v=56">money</a> for Mobile 1 and get twice as much mileage out of it.
What you guys think?
With any quality oil you can go for longer periods of time between changes. I would rather have the better oil. How long you go is up to you. How hard your drive your car also makes a big difference. Any SC and especially turboed car should get good oil and change it pretty frequently.
Vikto....there is no right answer. Bill's Oil Spreadsheet is the closest anyone has come to comparing as you ask. Each approach has it's own pro's and con's. Better synthetics, like Mobil 1 & Amsoil, allow you to extend the drain out longer with confidence. 6K like you said, or 1OK, or more if you want. Synthetic runs cleaner, do better at temp extremes, and U may ulimately consume less oil if you extend the oil drain interval enough. Whether anyone owns a car long enough these days to enjoy all those benefits is also a good question. Mobil 1 is usually more expensive to buy and may not necessarily generate lower engine wear than regular oil. And if you enjoy working on your car, changing the oil every 3K with regular oil is more "fun" and cheaper than Mobil 1. Plus the new GF-4/SL oils out now may perform even better than GF-3/API-SL. Time will tell. Ultimately it's an individual thing. Searching for the best oil can be like this:
Originally Posted by 98MikeXimaSE
i just do mobil 1 supersyn every 3k miles and thats like 4 times a year =)
I do mobil1 in both maxes about every 7500 miles. I could get away with dino and be in spec for the manual but I play it safe and do the syn. I know with certainty that my engine is superbly lubed because of it.
Not to mention it can be a selling feature later on. If you take care of your car, and you're selling it sometime down the road, if you're looking for top dollar because you've kept it up, having an engine that's run on synthetic with regular changes certainly helps.
Originally Posted by mzmtg
Read the link I posted and stop pouring money down the storm sewer.
The only thing I started to do differently within my 10000 mile intervals with Supersyn is change the filter at around 5000 miles.
Originally Posted by kevlo911
Deezo, are you changing the Nissan filter at 5k miles or do you use a different type?
Also, I'm not Deezo.
Yes, mzmtg I figured the second part out
So I will only lose 1/4qt of oil when I change hte filter at 5k miles correct?
-matt
Originally Posted by matty
Im the same way...Mobile 1 Super Synthetic every 3K miles...I have the s/c so I want as clean oil as i can get to run through there
-matt
-matt
Originally Posted by wu54736
MaximaMan 5-30 in the winter and 10-30 in summer? If you don't mind me asking, what benefits do you get from doing this? Anyone else doing the same?
Originally Posted by MaximaMan77
From late May early June through September it gets quite hot here in Atlanta and most of my driving is done locally. Most of the roads here are asphalt and the temps on the road are usually well over 100 deg during the day. I feel that using 10-30 is better than the lower weight when it's that hot, other wise I use 5-30 the rest of the year.
They are both all-season oils and perform the same in hot climates.
I just use 5W30 which is recommended.
Castrol GTX every 3750 for now. Syn every 5000 after 20k miles. maybe 10k oil change/5k filter change after warranty.
Originally Posted by NismoMax80
but the 30 is the top of the range as to how "thin" it can be. 5 vs. 10 is how "thick" you want it in the winter. 5-30 includes 10-30 so what's the point? the W designates it is for Winter use.
"MULTI-VISCOSITY OILS
Multi viscosity oils have polymers added to a light base (5W, 10W, 20W), which prevent the oil from thinning as much as it warms up. At cold temperatures the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up, the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C, the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot.
Multi-viscosity oils are one of the great improvements in oils, but they should be chosen wisely. Always use a multi-grade with the narrowest span of viscosity that is appropriate for the temperatures you are going to encounter. In the winter, base your decision on the lowest temperature you will encounter; in the summer, the highest temperature you expect.
10W-40 and 5W-30 require a lot of polymers (synthetics excluded) to achieve that range. The polymers can shear and burn, forming deposits that can cause ring sticking and other problems. This has caused problems in diesel engines, but fewer polymers are better for all engines. The wide viscosity range oils, in general, are more prone to viscosity and thermal breakdown due to the high polymer content. It is the oil that lubricates, not the additives. Oils that can do their job with the fewest additives are the best. Follow your manufacturer's recommendations as to which weights are appropriate for your vehicle."
The cost is the same either way...
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
