Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Is my paint job permently ruined???
Old Oct 11, 2004 | 07:40 PM
PTP's Avatar
PTP
OK so there is this huge tree branch over my drive way and Ive been parking under it for several months. I know I know it was stupid and I am dumb for parking there but whats done is done. The situation is that after all these damn hurricanes bringing crazy rain, tons of crap has fallen outta the tree onto my Max, which is white by the way. So Ive tried to wash it with several different kinds of stuff and even used bug and tar remover but theres these small brown stains all over the hood and roof. Almost like freckles...I guess from nuts and whatever else can fall outta tree.
Is there any way to clean em off or is my paint job screwed??
Old Oct 11, 2004 | 07:46 PM
Bl_asd's Avatar
use wet sand paper? use 2000 grain
irish44j's Avatar
retired moderator
you sure it's not chips that are rusted?
Old Oct 11, 2004 | 07:50 PM
PTP's Avatar
PTP
Ya im positive its not any chips, the surface is still really smooth. Ill try an take a pic soon.
Old Oct 11, 2004 | 07:53 PM
DAP's Avatar
DAP
You can probably remove it with wax. Just use a cleaner wax and your some elbow grease. If the spots are small your finger nails should help get it off too.
Old Oct 11, 2004 | 09:02 PM
† ErV †
Rubbing compound, follow on with a polishing compound. If that don't work, cry and take a photo.
Old Oct 11, 2004 | 09:04 PM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
Send a PM to PrinzII and see if he can help. If he doesn't find a solution for you, then yea - start crying.
Old Oct 12, 2004 | 08:48 AM
pharmer's Avatar
Don't try wetsanding until you other options are exhausted.
Try posting your problems in the "detailing" section. I've found it unbelievably helpful...
Old Oct 12, 2004 | 03:31 PM
JdoubleOe703's Avatar
teddibear703
buy a claybar... its probably just stuck like tree sap or such... the claybar should work...
Old Oct 12, 2004 | 06:44 PM
fatboyp's Avatar
I second the claybar idea. I had a light mist of road tar sprayed on my car and the only thing that took it off was a claybar and elbow grease.
Old Oct 13, 2004 | 08:11 AM
pharmer's Avatar
Claybars remove everything, so you'll need to wax afterward. I'd recommend claying it, then using a good pure paint polish. If that doesn't work, go to your local paint shop supplier/auto body store and ask them what sort of compounds might work.
Old Oct 13, 2004 | 12:17 PM
Bman's Avatar
Unless they're spots that you can actually tell that they are "junk" sitting on top of the paint, I'm not so sure that clay would do much. Try it first though.
If that fails, try working some of your car wax into the paint and see if that is strong enough to fix it. If not, try scratch remover. Then fine cut rubbing compound, and then really gentle wetsanding as an absolute last resort. Rewax once you've fixed it.
It is possible that chemicals from the leaves has had a chance to bake on the paint, so it has stained or chemically damaged the paint on those spots, requiring you to (gently) remove paint until undamaged paint is exposed.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
