Fuel Injector O-ring Lubricant
I am planning on replacing o-rings of fuel injectors. The Haynes Manual says that I should lightly lubricate the rings with "light grade oil," but I am not sure what "light grade oil" means.
Can I use a little bit of engine oil I have (Mobile 1, 5W-30) to lubricate them? If not, exactly what kind or brand of oil should I get?
vaseline not recommended.
while you can use petroleum based products (vaseline is a petroleum based product) for o ring lubrication, it is NOT advisable. you should instead use silicone grease. rubber can have serious reactions to petroleum based products. they can swell and soften as a result of using petroleum based lubes for o rings. this leads to the potential for failure. stick to the smart side and use silicone based grease.
and that we use rubber to keep petroleum products from leaking is a mystery (sarcasm). must be cheaper than other methods.
http://en.wikipedia.org/wiki/Silicone_grease
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
