Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Fuel Injector O-ring Lubricant
Old Oct 15, 2004 | 07:10 AM
hasei's Avatar
日産
I am planning on replacing o-rings of fuel injectors. The Haynes Manual says that I should lightly lubricate the rings with "light grade oil," but I am not sure what "light grade oil" means.
Can I use a little bit of engine oil I have (Mobile 1, 5W-30) to lubricate them? If not, exactly what kind or brand of oil should I get?
Old Oct 15, 2004 | 08:06 AM
mzmtg's Avatar
Minister of Silly Walks
Engine oil or vaseline.
Old Oct 15, 2004 | 08:48 AM
hasei's Avatar
日産
Thanks. I never thought of vaseline, though.
Old Oct 17, 2004 | 06:57 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
vaseline works great! Just make sure you don't overdo it at all.
Old Nov 16, 2011 | 09:14 AM
bmanjamz's Avatar
vaseline not recommended.
while you can use petroleum based products (vaseline is a petroleum based product) for o ring lubrication, it is NOT advisable. you should instead use silicone grease. rubber can have serious reactions to petroleum based products. they can swell and soften as a result of using petroleum based lubes for o rings. this leads to the potential for failure. stick to the smart side and use silicone based grease.
and that we use rubber to keep petroleum products from leaking is a mystery (sarcasm). must be cheaper than other methods.
http://en.wikipedia.org/wiki/Silicone_grease
Old Nov 16, 2011 | 09:37 PM
asand1's Avatar
Thats freakin hilarious, because last I checked gasoline was petroleum based too. All O-rings are not created equally.
Old Nov 21, 2011 | 11:41 AM
asand1's Avatar
O-rings are neoprene are not affected by petroleum products.
Old Nov 21, 2011 | 11:42 AM
asand1's Avatar
O-rings in atomotive engine applications are neoprene and not affected by petroleum products.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
msellas
Sep 23, 2015 09:16 PM
