Exhaust?
2.5" is best. For top end I have gone to a 2.75" once, It worked out well and got the car moving. When I went back to 2.5" I picked up alot of lowend loss that I didn't realize was there. With that 3.5L though, you could probably get away with a 2.75 to get a happy medium.
Well you gotta think about it, our stock size is 2.25" -- but that 1/4" opens it up a lot. 3/4" is WAY too big for NA. Even with cams and other NA motor work done.....there still isnt a significant amount of air flow into the motor. (As compared to boosting). Not only will NA 3" sound like hell, but it MAY also cause a big loss at low end....but at top end...thats different.
But what do I know..
Thw apexi ws I have is 2 3/8 from the cat to where it bends over the axle, after that it's 2.5. I think that even 2.5 is a bit big for most n/a people on this board. Our stock size isn't 2.25. It's most likely 2" if you take all the bends and crushes into consideration. It becomes 2.25 near the muffler. Also y-pipes aren't 2.5 til they get past the flex, before that they are around 2".
so what would a good exhaust cat back (CALI) setup be for a STOCK vq30de-k be?
2.5?
Or y pipe and header's/collector's (can't afford yet)?
And... mildly off topic but not out of the thread heading... are the pre-cats restrictive and should I try and do the sensor bypass fed pipes for more balanced back pressure?
Or....... leave the setup the way it is and get custom headers?
HELP!!
2.5?
HELP!!
Originally Posted by MrRogerStatus
so you're saying its not neccessary to have a B- pipe?
