Clutch replace and car won't start - also tranny seal question.
Ok. need some help.
I finally finished the clutch replacement but I can't get the car to start.
I've got everything back together again but when I tried to start the car up it turns over but won't catch.
It appears that everything required to get the starter to turn over is fine since the starter is going. That should mean the grounds are correct, the starter connections are ok, and the connectors are attached properly. Is it possible that there is still a problem with the starter even if it is turning over?
Any thoughts?
The items I can think of are the air intake system, the fuel system and the computer system.
All portions of my cai are properly attached and the connector is attached. I can smell fuel after attempting to start several times so I presume that there is no problem with the fuel.
The only thing I can think of is that during one of the hurricanes here in Florida a lot of moisture got in my garage - the starter and crank position sensor were sitting out. Could moisture have damages one or the other?
ALSO - I'm not sure I have the driver's side axle properly seated. I replaced the tranny seals (don't ask me why - it just caused me problems). Does anyone know if you should be able to see any of the seal once the axle is in?
thanks in advance!
Any thoughts?
thanks in advance!
Originally Posted by Dave B
Verify that the clutch interlock switch under the clutch pedal is working.
I am not exactly sure how it works with Maximas. I have done a couple swaps with Hondas though. I know on the Honda, their is a ground wire that connects to the tranny and will cause it to crank over but not start if you did not hook it back up. You might still have a ground problem somewhere. Good luck!
Originally Posted by njmodi
Dave - I thought that that would prevent the cranking too... i need to do some
Check crank position sensor (POS) which is located on the tranny bell housing. It looks at the flywheel for ignition timing. It's in the area which you've taken apart. If it's bad or cannot "see" the flywheel, you will get a no start condition.
Turns out . . . .
That the car must have been flooded. BlackbirdVQ suggested that I floor it and start - apparently under that condition no gas goes to the engine. Bingo!
Also, I cleaned the crank pos and checked and redid all connections.
thanks for the help!!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
