Using just the NX nitrous solenoid, ie no fuel noid...
Old Oct 22, 2004 | 01:00 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
1)Can this be done to a NX#20923 kit for a pseudo dry kit?
2)Would a NX Maximizer work in this pseudo dry configuration?
I don't want to spray fuel through my composite intake manifold and I know NX solenoids/kits are more bullet-proof and guaranteed even when used with the Maximizer or pulsed by an ECU.
Old Oct 22, 2004 | 07:38 PM
SonicDust187's Avatar
I think you can run fuel with the composite intake just not a DPI kit.
Old Oct 24, 2004 | 10:13 AM
Jime's Avatar
Many guys run fuel through composite manifolds, no problem.
Don't think I would spray without the fuel, might get away with a 35 shot but I wouldn't do it.
Old Oct 25, 2004 | 10:47 AM
IceY2K1's Avatar
I can add fuel through the 4XXcc injectors as long as I don't outflow the MAF. I'll just go dry NOS probably, but I prefer NX noids for pulsing and definitely their accessories, *IF* it can be run that way.
Between the composite material degrading from fuel over time, risk of secondary chamber backfires(Nigel has had that with MEVI/wet), unknown cylinder fuel distribution, several areas prone to puddling, I'd rather not have fuel through the manifold.
If the injectors can handle a 100-shot or less by increasing injector duty cycle ONLY, can this be done? I know that bottle pressure will influence AFR with this setup, but if it's conservatively rich for max bottle pressure, the risk of going lean would be less.
Old Oct 25, 2004 | 11:06 AM
If you going to run bigger injectors then you can go dry without a problem.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
homeofbacon
Sep 23, 2015 07:17 PM
