Using just the NX nitrous solenoid, ie no fuel noid...
Old 10-22-2004 | 01:00 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
1)Can this be done to a NX#20923 kit for a pseudo dry kit?
2)Would a NX Maximizer work in this pseudo dry configuration?
I don't want to spray fuel through my composite intake manifold and I know NX solenoids/kits are more bullet-proof and guaranteed even when used with the Maximizer or pulsed by an ECU.
Old 10-22-2004 | 07:38 PM
SonicDust187's Avatar
I think you can run fuel with the composite intake just not a DPI kit.
Old 10-24-2004 | 10:13 AM
Jime's Avatar
Many guys run fuel through composite manifolds, no problem.
Don't think I would spray without the fuel, might get away with a 35 shot but I wouldn't do it.
Old 10-25-2004 | 10:47 AM
IceY2K1's Avatar
I can add fuel through the 4XXcc injectors as long as I don't outflow the MAF. I'll just go dry NOS probably, but I prefer NX noids for pulsing and definitely their accessories, *IF* it can be run that way.
Between the composite material degrading from fuel over time, risk of secondary chamber backfires(Nigel has had that with MEVI/wet), unknown cylinder fuel distribution, several areas prone to puddling, I'd rather not have fuel through the manifold.
If the injectors can handle a 100-shot or less by increasing injector duty cycle ONLY, can this be done? I know that bottle pressure will influence AFR with this setup, but if it's conservatively rich for max bottle pressure, the risk of going lean would be less.
Old 10-25-2004 | 11:06 AM
If you going to run bigger injectors then you can go dry without a problem.
jmlee44
10-02-2022 02:13 PM
aw11power
10-10-2021 04:57 AM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
homeofbacon
09-23-2015 07:17 PM
Quick Reply: Using just the NX nitrous solenoid, ie no fuel noid...
