Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Any side effects of having too much ATF?
Old Oct 24, 2004 | 04:08 PM
DeepBlueSE's Avatar
Well, finally got around to doing the DR Mod, Hayden tranny cooler, and tranny flush. Took me two days and 12 qts of Mobil 1 ATF. Anyway, as I was checking ATF levels I seemed to have gotten it right after numerous tries.
I followed the method by checking levels when HOT as suggested in the STICKY. My level was right in the middle of the HOT range. "Awesome" I thought. I went back in, got a soda, and decided to check it one last time. WTF? Now it was reading a bit above the HOT range. Do take note that I had been driving around some so engine was hot and this was with my tranny cooler installed as per the FAQ. Hmmm. So now what? Do I need to drain it some or will it be okay?
On a side note, I decided to my engine oil level and was shocked to learn that it too was way over. Granted my engine was hot so I guess I'll check again when it cools. I know I only put <4.5 qts of oil.
Old Oct 24, 2004 | 04:25 PM
kcryan's Avatar
for the engine when its hot it pours oil down out of top of engine down onto dip stick. or at least thats how i understand it
Old Oct 24, 2004 | 04:33 PM
DeepBlueSE's Avatar
okay that makes sense... now about the tranny, anyone else wanna chime in?
edit: yup, checked the oil level when engine cooled down and it was normal, heh.
Old Oct 27, 2004 | 11:31 AM
DeepBlueSE's Avatar
bump, still need the atf ? answered
Old Oct 27, 2004 | 12:17 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
ive always heard it can cause air to be entrained and affect clutch operating pressures and shift quality. some have mentioned foaming of the fluid but i believe that where it was severely overfilled. in some makes, the fsm states to overfill but ive never heard of that practice with nissan.
Old Oct 27, 2004 | 12:25 PM
Mizeree_X's Avatar
Getting back to his roots
I would think overfilling would cause higher fluid pressures, which may wear down the pump and/or seals that are exposed to the higher pressure. Not 100% sure on that, just a guess.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
bigdogsteve
Jan 31, 2018 04:18 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Noela
Sep 26, 2015 08:22 AM
