WOOT in the 14s now!
Finally its about time. It was just the tires that I was having a problem with. My launches with my stock tires were horrible and I could never get traction and if I tried not to I would bog so I threw on some slicks and got myself a 15.2 I believe for the first run then I hit a 14.9 and 15.0 then low 15s for the night.
with street tires
Btw im car 326 and my mods are SP2 catback, B&M STS, budget Ypipe,and tein coilovers.
with street tires
Originally Posted by Gmahoney
Also y2ksesteve was running 14.8's on stock tires that night after we threw on the slicks he was running 14.9 with a lower trap speed as well ...
Steve got slower on slicks...traction issue or clutch?
Edit: I'm running a JWT clutch with about 5k miles on it... It grabs hard all the time. Track conditions weren't as good as they could have been, but most everyone was running fast.
Originally Posted by Y2KSESteve
The drag radials were at 25 psi. We probably could have gone lower but had to use them for the drive home.
how many miles on your car and when was your last tune up? your times are respectable but you should be running those times on street tires. i believe steve metioned your car is also cali spec and you are a 5speed?
Oh and id have to check on that tune up cause I bought the car with 54k miles on it and I put about 3k on it so far so its not very old but im not sure about the tune up. I will have to change the oil soon here I put in synthetic right when I got it then I just put in some new NGK copper plugs and stuff running 91 octane gas
well you should deffinately have the potential to have mid to low 14's. only 57k your so lucky my car now has 111k.i would checkup on the tune up new plugs and maybe a fuel filter. its pretty cheap stuff you can do yourself and it makes a world of diffrence. if my car can do it your car can.
The best I could pull was like a 2.283 on the DRs. The other run was a 2.3 something.
im really lost here. I thought Steve has JWT ECU and clutch/flywheel, headers, MEVI.... etc. then he adds slicks and his car is still high 14's. Am I an idiot or what. WHat is the elevation and track conditions?
No ecu for steve yet. He has the rest of the stuff so pretty much the mevi is minimal power for him. That ecu will drop his time significantly. I dont know much about his launches but I know mine are terrible without the slicks. He said he was launching the same as I was... Some times I would drop it at 4k sometimes at 5k.
litch
Sep 5, 2015 11:29 AM
