ECU error code
Old Nov 5, 2004 | 01:22 PM
Epacy's Avatar
Unsuccesful STL Coordinator
ECU error code
Alright. I have and error code that reads as such:
P0455 System Leak (Large) Emission Control
I loaded up on fuel the other day and I thought the gas cap went on screwy. Then the code appeared 1 to 2 days later. So I reseated the gascap and reset the ECU. The "Service Engine" light still came on. So either I didn't reset the ECU correctly, although I have done it before, or the problem still exists. Has anyone had this specific error code before and what was the fix. I know this is not a very specific code so any help would be appreciated.
Old Nov 5, 2004 | 03:11 PM
MAX0830's Avatar
i have that same problem its aprox $500 to replace it...its that black box underneath the car to the right of the spare tire there is a valve inside of it and its either stuck open or shut it vents out gas fumes when you fill your car up with gas
Old Nov 5, 2004 | 03:25 PM
Epacy's Avatar
Is it in the trunk or under the trunk? Just underneath the car to the right where the spare would be? The gas cap is on the driver's side and I know there is some black box thing on the left side on the inside of the trunk if you are looking at the trunk.
Old Nov 5, 2004 | 03:37 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Just drive around for awhile, it will reset. Autozone or someone with one of the newer CAN bus compatible OBD scanners can probably reset it for you.
2K2+ don't let you just unplug the battery to reset anymore.
Old Nov 5, 2004 | 03:45 PM
Epacy's Avatar
Ice, I have reset the ECU and driven around the problem is still there. Even with reseating the gas cap. So, it seems like it might be something else.
Old Nov 5, 2004 | 03:51 PM
IceY2K1's Avatar
How did you reset it?
Old Nov 5, 2004 | 04:08 PM
Epacy's Avatar
Update
Acclerator Pedal.
I reset the ECU twice and the second time the CEL light didn't come on. Looks like it might have been the gas cap. Thanks all.
Not sure about your deal MAX0830. I saw a black box on the underside of the trunk on the driver's side. That doesn't look to hard to replace as long as the part itself isn't $500. If that is even what you are talking about.
Old Nov 6, 2004 | 06:45 AM
MAX0830's Avatar
it is the black box underneath the car next to the spare tire..and no it doesnt seem too hard to do i was gonna try and do it when i went back to my house...from what i was told the parts arent too expensive
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
