RSB Install time
Originally Posted by Matt_01SE_20th
i just backed mine onto ramps and was able to do it in like 30-45 minutes.
I jacked mine up too. I took the wheels off and put them under the car and then rolled under there. I did it in about 30-45 minutes as well. It wasn't real tough, just have to make sure it is in the right place or you will get the banging of your life from the rear end.
Originally Posted by midnightmax01
does anyone other than stillen make a rear sway bar for the 01 maxima ? cause if so i might have to buy one.
http://forums.maxima.org/showthread....16#post3221016
Peace.
You should be able to get Craftsman jack stands at Sears for $20 a pair.... maybe even less if ya can find some generic ones.... its worth the investment esp if you're gonna be doing more work on your car down the road...
I did mine with ramps. Load is not an issue since the rear bushings allow movement of the rear beam anyway.
http://www.win.net/audtatious/audio/tech/addcorsb.html
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
