Auto tranny normal temp?
Old Nov 13, 2004 | 03:00 PM
waveridr85's Avatar
Wat are you guys getting for normal operating tmeps on the auto trannies? i think mine is over heating. Thanks
Old Nov 13, 2004 | 11:14 PM
waveridr85's Avatar
bump, someone has to know
Old Nov 14, 2004 | 04:58 AM
njmaxseltd's Avatar
Are you running a tranny temp gauge? Does your fluid smell burnt or is it discolored in any way? What makes you think your tranny is running hot? It shouldn't overheat unless your towing something heavy on mountain roads or really beating on your car when you drive it. If you would like more protection try a synthetic transmission fluid such as Amsoil. Amsoil claims that their synthetic fluid helps keep temps down by reducing friction. Most on here would agree that their auto trannys run better when switched over to synthetic fluid. Mine sure does!
Old Nov 14, 2004 | 08:03 AM
DaThrillr's Avatar
i get readings around 120-150 in normal driving, and when driving spirited i get into the 180s, i have my temp manifold inline, on the line(cooled fluid) going into the tranny from what i remember.
Old Nov 14, 2004 | 09:18 AM
waveridr85's Avatar
Thanks, this is just because I have a torque converter and valvebody which tend to produce more heat. I ran two coolers and now i took one out. I noticed that I hit 180 the other day while spirted driving and wondered if it was too high. I never hit 180 before
Old Nov 14, 2004 | 04:24 PM
waveridr85's Avatar
bump for more opinions
Old Nov 14, 2004 | 09:12 PM
erty67's Avatar
Decal Specialist
I have a VB mod and a cooler. I'm usually around 150, but it does go up to 180 rarely. being in LI, go by Maximum Tuning and ask Jeff. i'm sure it's normal.
Old Nov 15, 2004 | 07:37 AM
Ninos_Maxima's Avatar
be the change u want2C
Whered you get a tq converter from??? I never saw one in Production?
Old Nov 15, 2004 | 07:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
anywhere between 160-180 or so is ok.
once you hit past 200 you need to calm down.
anything under 140 is a tad on the cooler side.
i've hit 215-220 on mine....hot hot day in NYC traffic.
Old Nov 15, 2004 | 07:49 AM
DanNY's Avatar
Ad·min·is·tra·tor
Level10
protorque
Old Nov 15, 2004 | 08:38 AM
can you link me please, ive been dying to see one, does the sight have any info on how well it works, ive seen some tq converters that make an auto tranny put harder shifts and more hp to the ground then manuals
Old Nov 15, 2004 | 08:50 AM
DanNY's Avatar
Ad·min·is·tra·tor
lazy
http://www.protorque.com/shopping/sh...san%2FInfiniti
do you understand the concept of higher stall TC? no company will make a claim on your HP level/gains because that really can't be established until it's on the car.
Old Nov 15, 2004 | 08:55 AM
No i know about that all, but isint that the whole point of a tq convo is to put the power loss of the auto tranny to its feet and make it work more efficently,,, right?
Old Nov 15, 2004 | 09:01 AM
DanNY's Avatar
Ad·min·is·tra·tor
yes and no....
it puts you in your powerband sooner than later...but power loss on an auto is always there.
Old Nov 15, 2004 | 09:21 AM
hahah good thing I met this guy here in China, hes gonna help me build my car when I get back, he builds hot rods, and he knows a **** load, im like mooching his knowledge slowly, Im planning on doing a weird *** swap when I get back, ill keep you posted, o yeh our axels are hollow right?
Old Nov 15, 2004 | 09:32 AM
DanNY's Avatar
Ad·min·is·tra·tor
wtf are you talking about?
Old Nov 15, 2004 | 09:51 AM
lol, well im in china right now, ive been here for 4 months, and I met another guy here that builds custom hot rods for a living, i told him about my car, and how I tune it, but when I get back him his brother and me are gonna work on my car with a special little somn, I was asking if nissan maxima transaxels are hollow
Old Nov 16, 2004 | 08:31 AM
waveridr85's Avatar
Back on topic, the converter is a protorque and max stall is 3200
Old Nov 16, 2004 | 10:36 AM
Aaron92SE's Avatar
NWP Engineering.com
Max Stall? What do you mean by that? There are several different ways to determine stall... tach stall, brake stall, flash stall, etc. They are all going to be different than one another. What are you able to stall to if you hold the brake and press the gas? Does it over power the brakes? If so, that is not going to be a good measurement. Flash stall is what rpm you see on your tach when you stomp on the gas with perfect traction. My stock "brake stall" is 1800 rpm. After my TC install, I can now get 2600. But my "True stall" is going to be around 3000 rpm. My brakes hold well enough for me not to over power them during the brake stall test. An 800 raise in stall is not bad at all. I am happy.
www.edgeracingconverters.com is a GREAT company. They made my high stall torque converter and I am very happy with the service I got! Andre is great! He also built a G35 torque converter and it turned out great. They say they are one of, or THE oldest torque converter performance shop in the nation. So usually, the older the place is, the bigger their database is and the better they can build you a torque converter to suit your needs.
About my tranny temps, in 110 degrees in Las Vegas, I would see 180 at the MOST with my AC blasting. I read somewhere that normal dino tranny fluid starts to break down at 180. But it's not crutial until you see something over 200 degrees. My normal operating temp in Las Vegas extreme (110-115 degrees) weather is 140-170. I have a tranny cooler.
When I added "Trans Cool" made by Pro Blend 40 below (Pep Boys and Advanced Auto parts carries it), my tranny temps dropped more than 25 degrees!!! So now, I haven't seen anything above 150 in a long time! Anything below 125, I think, is getting on the cool side.
Old Nov 16, 2004 | 10:14 PM
DanNY's Avatar
Ad·min·is·tra·tor
did you drop enough company names in this post?
Old Nov 17, 2004 | 06:26 AM
Aaron92SE's Avatar
NWP Engineering.com
When I find a great company or product, I try to let it be known.
Old Nov 17, 2004 | 10:24 AM
waveridr85's Avatar
Aaron, 3100 brake stall is what i can get up to.
I have found by asking nissan techs that if the tranny is too cool it will put stronger strain on the gears. as of now, I have not been able ot find out what the best operating temp from nissan
Miket2006
Mar 1, 2021 03:55 AM
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
