Sunroof
Old Nov 17, 2004 | 12:03 PM
bhaske1's Avatar
Sunroof
So my 96's sunroof was tilted open, now it wont close.
I can hear the motor running when the switch is moved to tilt open more only, so I ordered/installed a new switch.
Nothing....... before it rains...
THANKS!!!!!
Old Nov 17, 2004 | 07:04 PM
MadChef's Avatar
Sorry to tell you this but your track is either broken, or the wire has come off the track.
The track repair kit is only $30 or so, but labor is somewhere around $400-$500 at the dealer.
You can do the repair yourself (I did), but it's a lot of work:
http://www.vqpower.com/v2/modules.ph...howpage&pid=43
Good luck!
Old Nov 17, 2004 | 08:23 PM
bhaske1's Avatar
So I was able to close it manually by crank under the dome light.
It freed itself up, and now works. But got stuck again, so I used the crank to shut it.
So at least it works and if it gets stuck I know the procedure..
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
