OEM alarm going off! Need advice
Old Nov 17, 2004 | 12:21 PM
Max96GLE's Avatar
My OEM alarm is going off. I think the system is useless. I'm thinking of disconnecting the alarm. Anyone know the location of the OEM alarm? The wire color code?
The OEM remote has a panic button. What does it do? where is the signal going to when I press that button? Anyone knwo the wire info? I want to use that button for something else. thanks
Old Nov 17, 2004 | 12:27 PM
njmodi's Avatar
Do I get a tax break?
If you keep the panic button depressed for a few seconds, the car alarm will sound (beep beep beep, etc)....
Old Nov 17, 2004 | 12:54 PM
Conrad283's Avatar
I need a truck
That has nothing to do with what he's talking about.
Try posting in the audio/electronics forum.
Old Nov 17, 2004 | 12:58 PM
njmodi's Avatar
Ummm.... excuse me but it does... the second part of his post reads:
I was not suggesting that it was the reason his alarm was going off - if thats what you meant.
Old Nov 17, 2004 | 01:02 PM
Max96GLE's Avatar
Thanks for the info NJmodi. That's what I did to disarm it. Now my problem is, I want to remove it completely. I want to know where the unit and wires location.
Old Nov 17, 2004 | 01:03 PM
njmodi's Avatar
Max96 - what did you do to disarm it - I didn't follow.
Old Nov 17, 2004 | 01:05 PM
Max96GLE's Avatar
I press the panic button to disarm it.
Conrad283's Avatar
I need a truck
My bad totally messed up reading that. I think that the alarm box is somewhere underneathe the steering column. But don't go cutting wires. That's where my Viper alarm is hooked up to, but I didn't do the install.
Old Nov 17, 2004 | 01:09 PM
njmodi's Avatar
I think pressing the lock/unlock will also turn off the alarm if its going off... (can't remember for sure).
As already stated, you don't want to start cutting wires...
Does the problem only happen when you are near the car (i.e. when the remote is within range) ?
Old Nov 17, 2004 | 01:10 PM
Max96GLE's Avatar
Since the alarm is so annoying, I have no use for it. I figure I can use the Panic button for another channel. All I need is the location of the alarm and wire info. Once I have these info, I can cut it out for good and use the Panic Button for other mods. Ex. turn on headlight etc..
njmodi's Avatar
No probs.
Old Nov 17, 2004 | 01:11 PM
Max96GLE's Avatar
it doesn't happen often, I think the OEM alarm is useless. I just want remove it.
Old Nov 17, 2004 | 02:33 PM
sunten1
make suyre u don't kill ur battery by leaving the alarm on too long
Old Nov 17, 2004 | 05:09 PM
Igobuk's Avatar
Your alarm "brain" is behind your cigarette lighter/ashtray area. You have to remove the clock, A/C controls and radio to get to it. There's a picture of it and everything in the VQ Power How-to when you want to add a shock sensor. Below is the link.
http://www.vqpower.com/v2/modules.ph...howpage&pid=13
Old Nov 17, 2004 | 06:32 PM
Max96GLE's Avatar
You mean the BCM (Body Control Module). Yeah, I kind knew it control the 5 LCU's. I had some experience with the module a week ago. Turn out it wasn't the "Brain" causing the problem.
Anyone know where the "Panic Button on remote" signal go when press? Where is the receiver located?
Old Nov 18, 2004 | 07:36 PM
quasidynamic's Avatar
Max96GLE: see this thread: http://forums.maxima.org/showthread.php?t=355489
Should have all the wire info you need.
Mahmuth
Aug 16, 2024 08:23 PM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
atriuum
Sep 28, 2015 01:19 PM
