What has to be done to get 4th gen injectors to fit 00VI lower manifold?
Originally Posted by Stephen Max
Anybody know?
You could get the 4th gen lower welded and machined to fit the 00 upper
Originally Posted by Pimpmobile
nothing, they are not compatible. Atleast the 00 fule rail isnt. The 4thgen injectors are side feed while the 00+ are top feed.
IIRC
IIRC
Yeah, I know. But as far as inserting the 4th gen injectors and fuel rail into the 2k lower IM, what needs to be modified? Is it simply a matter of enlarging the diameter of the holes in the IM? Or what?
Much easier to weld and machine the top of the 4th gen manifold to fit the desired application
Originally Posted by krismax
you would have to weld more metal in those spots and machine it like the 4th gen holes then weld and make tabs so the rail can be bolted on like the 4th gen because the 00-01 bolts on very different.
Originally Posted by Nismo3112
Anyone know if I will run into problems when running the 00 injectors with like a JWT or Technosquare ECU programmed for the 4th gen?
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
