Door buld stopped working.
Old Nov 19, 2004 | 07:56 AM
dallas0593's Avatar
Door bulb stopped working.
So i take out the bulb [it was working] to replace with blue 194. I put in the new bulb and it doesn't light. I replace with 1 that i just took out and that 1 doesn't work either. I had some extra 194's laying around so i put each of them in and nothing. The driver door works so i know it's not the fuse [unless they are different fuses]. What could cause such a strange thing to happen. Maybe the receptacle blew? Is that possible just from putting in a new bulb?
Old Nov 23, 2004 | 01:33 PM
dallas0593's Avatar
Have i stumped the org?
Old Nov 23, 2004 | 01:49 PM
kbmaxima's Avatar
happened to a lot of people. still no solid explanation. just one of those things. That's why I put in led's so I'll never have to touch them again.
Old Nov 24, 2004 | 05:05 AM
dallas0593's Avatar
kbmaxima happened to a lot of people. still no solid explanation. just one of those things. That's why I put in led's so I'll never have to touch them again.
Really? Oh boy, guess it's time to go the LED way....oh boy this might get ugly
Old Nov 24, 2004 | 06:31 AM
sean05's Avatar
yup, mine are out too. Its my drivers side. How do you put leds in there?
Old Nov 24, 2004 | 06:33 AM
dallas0593's Avatar
Not a friggin clue
Old Nov 24, 2004 | 06:44 AM
willis's Avatar
My heroine
pshht... all of mine are out.. no bulbs work, no leds work, and the only fuses I can find for interior are fine..
the workings of the door lights are apparently a mystery, give up
Old Nov 24, 2004 | 06:55 AM
Max96GLE's Avatar
Happens to be too, but worst. Here's what you need to do first. If it doesn't work than try resetting the BCM.
First rotate the bulb. It might be different polarity.
Second, check fuse
Third:
Here's my story: My door lights out, key lights out, deforst out, window out, door lock out, remote out.
At the end, i reset the BCM. Open up the stereo head unit. There's a small black box behind the head unit. VQpower has a picture under the (installing shock sensor). Unplug the BCM unit and plug it back in.
That should do the trick. I know it work on my issue.
Old Nov 24, 2004 | 09:00 AM
s0ber's Avatar
My dome light doesnt work.. Never did since I got the car... All the fuses are fine.. Everything else works...
:stumped:
Gonna try that reset the BCM thing later today.
Old Nov 24, 2004 | 09:25 AM
Longboarderphil
yea im definetly going to try this. Is the BCM attached to the factory headunit, because i dont have one ne more.
Old Nov 25, 2004 | 11:17 PM
Max96GLE's Avatar
All max have a BCM. No, is not attach to the HU. The BCM is behind the headunit.
Old Nov 26, 2004 | 07:31 AM
SMX95's Avatar
Ok I have the same problem but may have an answer. You need POWER LOAD GROUND to make **** work.. I had my Advance elect. Teacher check out why they dont light back up.. Well this is what he did. Check the blub, they worked.. then checked the power coming from the door, it was positive. then checked the fuses they were all good. BUT! he noticed when he tested the 2 wires from the door, (if you take it apart from the plastic piece surrounding the blub) that both wires were giving juice. Which he said theres a bad ground somewhere because when pulling out the bulb if metal contact the teeth where the bulb gets power from it will automatically be grounded. I hope this helps I still dont have door lights...
Old Nov 26, 2004 | 10:12 AM
tommyali
ya it happened to me also so i just put and led in there
Old Nov 26, 2004 | 12:29 PM
BORQUA79's Avatar
nycmaximas member
I think thats my problem... I was doing some cleaning and I put my cuz to work and told him to swop out the white (yellow factory) lights on the door with some blue after market bulbs... He said he had a hard time pulling the passenger bulb out so he wraped a rag around a screw driver to pry it out... Next thing there was a hole in the rag and the bulb cam out but no other bulbs work in that socket???
I understand what you wrote but now what??? Its automatically grounded but how do you fix it? Is the wire fried? Go get that teacher back in your car and put his degree to work...LOL...J/K
Old Nov 26, 2004 | 01:12 PM
SMX95's Avatar
LOL. I was infront of my girlfriends house today when i decided to give it a further look. I decided to use a 12v led bulb. to my amazement the passenger side light worked but when the door closed the light got brighter... So there is a bad ground! a loose or dirty ground will give a dim light with the door close its the negative isnt touching ground therefore the lights turn off. So my conclusion is it may be just the switch by the door the one that turns off the lights when the door shuts. the negative ground wire def runs to those switches im going to pull mine out and clean it up redo the ground and see what happens. Yeah my teacher need a wire diagram of the door lights, so he didnt get a chance to fix them yet. Im doing my best by looking over the notes i took and reading the text book to further more my idea to fix this. Right now im in Manual transmissions.
Old Nov 26, 2004 | 11:55 PM
BORQUA79's Avatar
nycmaximas member
Wheres that switch??? I understand that the light turns off when the door is closed but wheres the switch??? I even swoped the driver socket for the pass socket (plastic holder that bulb fits in) and still doesnt work??? This thing is starting to bother me... i know its just a light and maybe thats why Its hitting a nerve... Get back in here after your finished experimenting and tell us what youve found...
D Mason
Jun 21, 2016 04:43 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
