Help check engine light- P0507
P0507 - Idle Speed Control System RPM Higher Than Expected
I today install back the stock air box and cleaned TB. and the check engine light came on.
Right now the does engine does idle a little higher and jerk around when braking. I know, I did not bend the TB plate.
What should I do?
reset the TB plate position sensor, drive it around and reset it self.
What should I do?
Thanks I am going try this first, if this don't work I going straight to the dealer. I hate this computer crap in the car, what a lose gas cap, cleaning the TB, missing 02 sensor, will set the light off. Basically, you can't do nothing to the car. I just like the good old cars.
Idle Air Volume Learning (Throttle Position Learning)
Operation Procedures
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
6spd4dsc
Mar 4, 2016 05:19 PM
