question about belts
Old Nov 19, 2004 | 01:07 PM
gsumax's Avatar
I just recently had my alternator replaced, and now once in a while i get this squeaking noise from one of my belts/pulleys. I figured that they probably didnt tighten the belt good enough, but I took the car back, and the guy says its probably because the belt is old and needs to be replaced. My question is, does a worn out belt make a squeaking noise before its about to go out, or is it most likely just a loose belt that they dont want to admit to?
thanks for your time.
Old Nov 19, 2004 | 03:14 PM
Matt_01SE_20th's Avatar
it could be both. belts do wear out and need to be changed, how many miles?
Old Nov 19, 2004 | 04:42 PM
gsumax's Avatar
80,000 but i bought the car used at 45000, i dont think the belts were changed before i bought it, so its still on the original belt.
Old Nov 19, 2004 | 04:53 PM
jeffchn's Avatar
Change The Belts Every 75k And Your Fine
Old Nov 19, 2004 | 07:00 PM
i think nissan recomends 60K mi. i have 74 on mine and i am on original belts. i am replacing them when i put the UDP on. i cant get the old crank pulley off though. i went to a performance shop and they said it would cast $65/hour and take 3 HOURS. i could do it in 1 if i could get that damn bolt off. they are sqeeking really bad when its humid out.
Old Nov 19, 2004 | 07:35 PM
SoonerFan's Avatar
Cletus
one reason could be that they are slipping (even if the belts are tight enough)
try belt dressing. its a spray for the belts. it conditions the rubber to get better grip and make the belts last longer
Old Nov 19, 2004 | 08:30 PM
Ammi's Avatar
350 Detroit Muscle
That's only a temporary fix. Noise will come back.
Old Nov 20, 2004 | 06:25 AM
jay929rr's Avatar
my belts are squealing like a pig also mostly just at start up when its damp outside. quite annoying. are they easy to change?
Old Nov 20, 2004 | 06:49 AM
SoonerFan's Avatar
Cletus
no its not. when i got new belts they were making noise so i sprayed them. that was a year ago and havent had a sound.
Old Nov 20, 2004 | 08:22 AM
jay929rr's Avatar
my belt noise always came back as well after spraying. Maybe u have some different stuff, mine just said belt dressing on the can.
Old Nov 20, 2004 | 01:39 PM
Ammi's Avatar
350 Detroit Muscle
When belt is old and making noise, belt dressing will only get rid of the noise temporarily. Best way to fix is to replace it.
Old Nov 20, 2004 | 03:07 PM
Maxima2000SE's Avatar
i have 69k and my belts squeal all the time when i drive through water and at start up in the cold. i was told $265 to replace drivebelt, and that they dont need to be tightened because our cars have self tighteners. a while back i saw someone on the forum had nissan coupons for $99 belt change but that was a few months ago...maybe they will do it again.
Old Nov 20, 2004 | 06:54 PM
Zero Deuce SE's Avatar
In my experience as a mechanic, belt dressing is very sticky and messy and only lasts a short while. I have never used any on my vehicles and try my best not to use any at work unless it's to check for slipping belts that I plan on replacing if they are worn too much or stretched to the limit.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
