Just pulled engine codes.....02 01 and 04 03
Old Nov 20, 2004 | 11:42 PM
maximaseefu's Avatar
just pulled codes after engine swap and got 04 03 TPS and 02 01 ignition signal circuit. I will have to check the TPS to make sure the spring is catching but what the hell does the ignition signal circuit code mean? coils?
Old Nov 21, 2004 | 08:57 AM
96explorerxlt's Avatar
Yeah, 0201 is a coils code...since you didnt g et a misfire code in any cylinders, you can measure the resistance of the coils, although that didnt work for me, a misfire code eventually appeared in cylinder #2.
Old Nov 21, 2004 | 08:59 AM
cool. what is the procedure for measuring coil resistance?
Old Nov 21, 2004 | 09:48 AM
MDeezy's Avatar
ohmmeter, and check for continuity in the packs.
Old Nov 21, 2004 | 11:11 AM
cool. thanks.
Mar 12, 2020 12:06 AM
crazyespn
Sep 3, 2015 01:30 PM
