warped rotors?
warped rotors?
I'm not sure how old my rotors are, but I know for the past 30k miles, I haven't replaced them. They are most likely 80k miles old lol.
Anyways, the car has been running OEM pads. The brakes have squeeled since the past 3 years I've had the car. Haven't changed them since.
I just want to swap out everything. However, how can you tell if a rotor is warped other than feeling it when braking? Can i feel it on the rotor itself or look for something?
I would think that after you can feel it pulsating (sp?) you either have to resurface it if its still good or get new pads and rotors. I know mine are bad but i don't have the time or money to change it right now.
The vibration in the brake pedal should be good enough.
However, I have noticed that the face of the rotor sometimes changes color a little when they're warped. In my case, they went from a very shiny silver to a somewhat brownish silver... looked just overall dirtier than before.
usually, the fronts go bad, right?
i am tryin to avoid replacing all of them, bu at this point i think i might as well. I want cross drilled / slotted in the front and whatever in the back.
What do you guys suggest for cheap rotors on the rear?
Apr 16, 2020 05:15 AM
