Tip for Radar Detectors
Here's a little tip:
Since the power outlet is so low, the power cord will get in the way of the stereo and climate control. What I did was use the velco that came with the radar detector and attached the velco (it has a sticky side) to the right inside foot well on the driver's side. I put the power cord inbetween the velco, so now the cord is pulled out of the way. Just sharing though it might be helpful b/c I remember reading somewhere about the power cord in the way.
or you can hard wire it to the power from the sunroof/light at the top... or if you have an autodimming mirror u can wire it to the power from there...
radar
I hardwired mine into the sunroof....just a question too...I leave it on all the time, should I do this? I don't think it takes much power so it should be ok when the car is off...I think the battery might even cut off the power after a few minutes. Does anyone know??
Re: radar
I think it would drain your battery a little. It probably is not the same as leaving the radio on though. That's the beauty of tapping in the accessory outlet. It's only hot when the car is on.
Re: Re: radar
how does one hard wire a radar detector?
What happens if you go through DC or Virginia? (I live near Philly, so it's possible for me, not so for all you SoCal guys)
basically what u do is u cut your cigarette adapter wire and instead of plugging it into the adapter u just connect the positive and negative to something in the car so it is a hard wire... the other end still connects and discontects from the unit like it always had... so when u go through a state like that u just disconnect the detector and hide it and the little end of the wire is sticking out and thats it... so its like connected permanent to the car but u can still remove the detector
How do you get access to splice these wires?
Originally posted by IceY2K1
Great tip! I never considered running it off the auto dim mirror or the sunroof.
u have to take the plastic cover off... i didnt look at it so i dont know how to do it but probably u pry the plastic glass that covers the bulbs off and it should expose a screw or 2 and u just unscrew those and pull the whole thing out and the wires should be there... i didnt do it yet on my car but there are people here who have and they would be able to tell u exactly how to remove the unit...
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
