Technosquare ECU w/Spray?
Old Nov 27, 2004 | 06:44 AM
ajsince81's Avatar
I was wondering if anybody is running a Technosquare ECU with nitrous? I always thought that your not suppose to change your ecu with nitrous, but Technosuare says it safe. If anybody is doing it, did it help your performance or is it a waste of $500. Is it worth the price?
Old Nov 27, 2004 | 07:50 AM
DaThrillr's Avatar
u can get their ecu but no advanced timing programs only raised limiter and if u changed plugs u can get those kinda programs ,,,, but N2O and advanced timing doesnt mix well.
Old Nov 27, 2004 | 02:32 PM
95maxrider's Avatar
Lightly modded
Since you have a 2k2, an ECU and nitrous probably won't work well together. If you had a 4th gen you could get the JWT ECU and their nitrous program. If it is possible to get the ECU without the advanced timing, then you should be fine, but that takes away all the benefits on the ECU. I don't think you will benefit $500 worth from just an increased rev limiter. Don't waste the money on the ECU, just work on getting your nitrous tuned perfectly.
Old Nov 27, 2004 | 04:17 PM
michaelnyden's Avatar
don't forget the more aggressive A/F graphs that come with the ecu....but you could tune that cheaper than an ecu using a SAFC
additionally, you could run the J&S ultrasafeguard...with the TS ecu....so when not spraying, you can run as much NA power as possible...the safeguard comes with a wire that you wire inline with your nitrous selenoid which retards the timing once it detects it is activated....and when it's not...your timing would return to the TS advanced timing...
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
