Malfunction indicator light on
Old Nov 28, 2004 | 06:21 AM
dzw's Avatar
dzw
96 maxima GXE 5 speed. Today when I drive, I found malfunction indicator light was on. The owner's manual says it may indicate a emission control problem. Does anyone know how to find the problem?
Old Nov 28, 2004 | 06:26 AM
chenzarino's Avatar
You mean the Check Engine Light? Look in the stickies for how to check the codes in the ECU, then let us know what codes you get.
Welcome to the org by the way!
Old Nov 28, 2004 | 06:37 AM
dzw's Avatar
dzw
The light is always on but not blink. The light on my 96 maxima owner's manual is called malfunction indicator light. I can not find check engine light in my owner's manual. Maybe these two light are same but have different names.
Old Nov 28, 2004 | 06:53 AM
s0ber's Avatar
its called a Check Engine Light, CEL.
Old Nov 28, 2004 | 07:18 AM
chenzarino's Avatar
If it says service engine soon, thats your CHeck engine light. It won't blink unless you put the car into diagnostic mode, then you can get the codes. Follow the link in the stickies under ECU codes
Old Nov 28, 2004 | 08:16 AM
dzw's Avatar
dzw
I check the code, it is 0111. What is the next I can do?
Old Nov 28, 2004 | 08:22 AM
MDeezy's Avatar
check the stickies at the top of the forums, there is a thread on figureing out what cel codes mean.
Old Nov 28, 2004 | 08:23 AM
MDeezy's Avatar
0111
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
dcam0326
Sep 7, 2015 07:26 AM
