can't shift from D3 to D4
Old Nov 30, 2004 | 06:10 AM
maximaer's Avatar
HELP!!
My love 1991 maxima se model has transmission problem for awhile, I can't shift the D3 to D4. After replacing the part still can't work it out. Can someone tell me how to find out the problem?? Thanks!!
Old Nov 30, 2004 | 06:54 AM
I30tMikeD's Avatar
There is a guy who has the exact same problem in this thread. Maybe you can help each other out?
http://forums.maxima.org/showthread.php?t=358459
Old Nov 30, 2004 | 07:26 AM
felix's Avatar
Sittin' On Chrome
Old Dec 1, 2004 | 05:33 AM
maximaer's Avatar
I can't read his threads!!
Old Dec 1, 2004 | 06:14 AM
Bonka's Avatar
Schnell kaputt
Did you check if the cable or the shifter was causing it?
To check if it's the cable, you'll have to disconnect the cable from the transmission's end. Move the shifter around to see if it moves freely.
If it doesn't move freely, you'll have to disconnect the cable from the shifter's end and then move the shifter. If it moves freely now then it's the cable.
If it is the cable, you'll either have to re-tighten (if possible) or replace the cable.
Usually the cable stretches when you put it in park and the car moves forward a bit until it locks or if you try to force it out of park.
Old Dec 2, 2004 | 03:40 AM
maximaer's Avatar
Thank you very much!!
I will try it today
Old Dec 2, 2004 | 10:32 PM
maxmiles's Avatar
Dosent it only have three drive positions with the fourth being the button on the shift handle?? (OD lite on dash)
Old Dec 4, 2004 | 12:11 PM
maximaer's Avatar
O/D on /off??
Does you mean the O/D on and off?
Actually I follow the manual to dignosis it, check thru all the transmission related cables, my technician even took off the transmission and clean it, but still can't fix problem. It can't shift from D3 to D4 automatically I can't drive it on the highway. I don't believe it can't be fixed. kind of upset about this!!
Old Dec 4, 2004 | 03:21 PM
maxmiles's Avatar
When the car is cold it won't shift into overdrive. There is a fluid temp sensor in the trans that has to see a certian temp before it will allow an upshift into fourth.
Just a guess since I get this complaint alot when the weather around here gets cold.
The trans in that car is pretty durable. Have your tech check(hey a rhyme) for resistance on the temp sensor.
Old Dec 7, 2004 | 04:45 AM
maximaer's Avatar
I tried already!! Temp sensor is OK
I tried already, the temp sensor is OK, also my tech clean the whole trans !! We suspect maybe the enectronical problem BUT can't really find the way out!! So wish me luck!!
Old Dec 14, 2004 | 11:34 PM
maximaer's Avatar
Finally find the problem!! The ECU for trans is malfunction. Now I need to find out where I can get one!!
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
